Before you can use Streaming SQL Console, you need to create a project where you can
submit your SQL jobs and manage your project resources.
Select SQL Stream Builder from the list of services.
Click .
Click New Project on the Projects
page of Streaming SQL Console.
The Create Project window appears.
Provide a Name to the project.
Optional: Provide a Description to the project.
Optional: Provide a prefix that overrides the Materialized View table
names.
Providing a prefix to the Materialized View tables names that overrides the
default one is an advanced option. The tables are prefix by default with the ID
of the projects to avoid collision between projects. This configuration allows
setting a custom prefix to the Materialized View tables created in the
project.
Optional: Provide the Source Settings of the
project.
Add a remote Github repository URL to the Clone
URL field.
You can use the following example URLs with or without
authentication:
- To clone without authentication:
https://github.com/cloudera/ssb-examples.git
- To clone and push with HTTP basic authentication
(username/password):
- To clone and push with SSH authentication (SSH private key):
git@github.com:cloudera/ssb-examples.git
- To clone and push a local git repository on the filesystem of
SSB host:
file:///usr/src/ssb-examples/
Provide the branch name or tag of the Github repository to the
Branch field. This branch is checked out when
pulling or pushing to the Github repository.
Enable or disable Allow deletions on import.
Enabling the allow deletion upon import allows you to hard-reset your project
to its versioned state when there are untracked resources in it. For example,
the job is deleted from the project when importing the project from Github if
the job does not exist in the repository. In other words, the upstream version
overrides the version you have in Streaming SQL Console. If disabled, the
project keeps the resources that were not pushed to the Github repository.
The
deletion affects the jobs, data sources, functions, Materialized Views and
their API keys.
Enable or disable Authentication for the project.
After you have created the project, you have the following
options to manage the project on the Projects page:
- Click Open to use the created project and start creating
SQL jobs.
- Click Switch to open another project than the active
one.
- Click Delete to remove the project from SSB.
