Using Apache FlinkPDF version
SQL and Table API supported features
The following SQL and Table API features are supported in Cloudera Streaming Analytics.
StreamTableEnvironment (Blink Planner) Catalogs
  • DataStream conversions:
    • Row
    • Tuple
  • Temporary views
  • SQL update and Query operations
  • Creating and using catalogs
  • Listing catalogs, tables, databases and functions
  • In-memory - Flink default catalog
  • Hive
  • Schema Registry
  • Kudu
SQL update statements SQL query statements
  • CREATE TABLE
    • Computed columns
    • Watermark definitions
    • Table connectors
      • Kafka
      • Kudu
      • Hive (through catalog)
    • Data formats (Kafka)
      • JSON
      • Avro
      • CSV
  • INSERT INTO
    • VALUES
    • SELECT queries
  • Basic operations
    • Scan, Project, Filter
  • Basic aggregations
    • Group By
    • Group By Window
    • Distinct (only windowed)
  • Joins
    • Time-windowed stream-stream join
  • User defined scalar functions (scalar udf)
