Using Spark Hive Warehouse and HBase Connector Client .jar files with Livy
This section describes how to use Spark Hive Warehouse Connector (HWC) and Spark HBase Connector (SHC) client .jar files with Livy. These steps are required to ensure token acquisition and avoid authentication errors.
Use the following steps to use Spark HWC and SHC client .jar files with Livy:
- Copy the applicable HWC or SHC .jar files to the Livy server node and add these
folders to the
livy.file.local-dir-whitelist
property in thelivy.conf
file. - Add the required configurations in the
/usr/hdp/current/spark2-client/conf
folder:- For Hive, in
/usr/hdp/current/spark2-client/conf/hive-site.xml
- For HBase, in
/usr/hdp/current/spark2-client/conf/hbase-site.xml
conf
field in the session creation request. This is equivalent to using "--conf" in spark-submit. - For Hive, in
- Reference these local .jar files in the session creation request using the
file:///
URI format.
HWC Example
- Add the add the following folders to the
file./usr/hdp/current/hive_warehouse_connector/
- Add
hive-site.xml
to/usr/hdp/current/spark2-client/conf
on all cluster nodes. - When running using the Zeppelin Livy interpreter, reference the HWC .jar file as
shown below.
%livy2.conf livy.spark.jars file:///usr/hdp/current/hive_warehouse_connector/hive-warehouse-connector-assembly-1.0.0.3.0.0.0-1634.jar
SHC Example
file./usr/hdp/current/hbase-client/lib, /usr/hdp/current/shc
- Add
hbase-site.xml
on all cluster nodes. - When running using the Zeppelin Livy interpreter, reference the following HBase
.jar files as shown below. Note that some of these .jar files have 644/root
permissions, and therefore may throw an exception. If this happens, you may need
to change the permissions of the applicable .jar files on the Livy node.
%livy2.conf livy.spark.jars file:///usr/hdp/current/shc/shc-core-1.1.0.3.0.1.0-65.jar, file:///usr/hdp/current/hbase-client/lib/hbase-shaded-protobuf-2.1.0.jar, file:///usr/hdp/current/hbase-client/lib/hbase-shaded-miscellaneous-2.1.0.jar, file:///usr/hdp/current/hbase-client/lib/hbase-protocol-shaded.jar, file:///usr/hdp/current/hbase-client/lib/hbase-shaded-netty-2.1.0.jar, file:///usr/hdp/current/hbase-client/lib/hbase-shaded-client.jar, file:///usr/hdp/current/hbase-client/lib/hbase-shaded-mapreduce.jar, file:///usr/hdp/current/hbase-client/lib/hbase-common.jar, file:///usr/hdp/current/hbase-client/lib/hbase-server.jar, file:///usr/hdp/current/hbase-client/lib/hbase-client.jar, file:///usr/hdp/current/hbase-client/lib/hbase-protocol.jar, file:///usr/hdp/current/hbase-client/lib/hbase-mapreduce.jar, file:///usr/hdp/current/hbase-client/lib/guava-11.0.2.jar
