Cloudera Data Science Workbench Command Line Reference
This topic describes the commands available to the Cloudera Data Science Workbench
    command line utility cdsw that exists within a Cloudera Data Science Workbench
    deployment. This utility is meant to manage your Cloudera Data Science Workbench cluster.
    Running cdsw without any arguments will print a brief description of each
    command.
In addition, there is a cdswctl CLI client that offers
      different functionality that is meant for use by data scientists to manage
      their sessions. For information about that see Cloudera Data Science Workbench Command Line Reference
Start, Stop, Restart for CSD Deployments: The commands available for a CSD-based
      deployment are only a subset of those available for an RPM deployment. For example, the CLI
      for CSD deployments does not have commands such as cdsw start,
        stop, and restart available. Instead, these actions must
      be executed through the Cloudera Data Science Workbench service in Cloudera Manager. For
      instructions, see Starting, Stopping, and Restarting the Service.
| Command | CSD | Description and Usage |
| cdsw start | Initializes and bootstraps the master host. Use this command to start Cloudera Data Science Workbench. | |
| cdsw stop | De-registers, resets, and stops a host. On a worker host, this command will remove the worker from the cluster. On the master host, this command will bring down the application and effectively tear down the Cloudera Data Workbench deployment. | |
| cdsw restart | Run on the master host to restart application components. To restart a worker host, use  | |
| cdsw join | Initializes a worker host. After a worker host has been added, run this command on the worker host to add it to the Cloudera Data Science Workbench cluster. This registers the worker hosts with the master, and increases the available pool of resources for workloads. | |
| cdsw status |  | Displays the current status of the application. Starting with version 1.4, you can use  The  |
| cdsw validate  |  | Performs diagnostic checks for common errors that might be preventing the application from running as expected. This command should typically be run as the first step to
                  troubleshooting any problems with the application, as
                  indicated by  |
| cdsw logs |  | Creates a tarball with diagnostic information for your Cloudera Data Science Workbench installation. If you file a case with Cloudera Support, run this command on each host and attach the resulting bundle to the case. |
| cdsw version |  | Displays the version number and type of Cloudera Data Science Workbench deployment (RPM or CSD). |
| cdsw help |  | Displays the inline help options for the Cloudera Data Science Workbench CLI. |
| cdswctl login | Enables you to log into the cdswctlclient. | |
| cdswctl projects list | Lists the projects. | |
| cdswctl models create | Creates a model with the specified parameters. | |
| cdswctl models list | Lists all
                models. You can refine the search by specifying the  | |
| cdswctl models listBuild | Llists the builds for a
                model. You can monitor the status of the build by specifying the  | |
| cdswctl models listDeployments | List the deployments for a
                model. You can refine the search by specifying the  Use the  | |
| cdswctl models deploy | Deploys a model with the specified parameters. | |
| cdswctl models listReplicas | Enables you to view the list of model
                replicas. You also need this information to obtain replica logs. | |
| cdswctl models getReplicaLogs | Enables you to view the logs for a model replica. | |
| cdswctl models restart | Restarts a model. Usage:
 Note: Running this command does not change the resources if you
                  previously ran the  | |
| cdswctl models update | Changes the name, description, or visibility of the model. To change a model’s resources, use the cdswctl models deploy command. | |
| cdswctl models delete | Deletes a model. Usage:
