Encrypted Write Ahead FlowFile Repository Properties
All of the properties defined above (see Write Ahead FlowFile Repository) still apply. Only encryption-specific properties are listed here. See Encrypted FlowFile Repository in the User Guide for more information.
Property
Description
nifi.flowfile.repository.encryption.key.provider.implementation
This is the fully-qualified class name of the key provider. A key provider is the datastore interface for accessing the encryption key to protect the content claims. There are currently two implementations - StaticKeyProvider which reads a key directly from nifi.properties, and FileBasedKeyProvider which reads n many keys from an encrypted file. The interface is extensible, and HSM-backed or other providers are expected in the future.
nifi.flowfile.repository.encryption.key.provider.location
The path to the key definition resource (empty for StaticKeyProvider, ./keys.nkp or similar path for FileBasedKeyProvider). For future providers like an HSM, this may be a connection string or URL.
nifi.flowfile.repository.encryption.key.id
The active key ID to use for encryption (e.g. Key1).
The key to use for StaticKeyProvider. The key format is hex-encoded (0123456789ABCDEFFEDCBA98765432100123456789ABCDEFFEDCBA9876543210) but can also be encrypted using the ./encrypt-config.sh tool in NiFi Toolkit (see the Encrypt-Config Tool section in the NiFi Toolkit Guide for more information).
nifi.flowfile.repository.encryption.key.id.*
Allows for additional keys to be specified for the StaticKeyProvider. For example, the line nifi.flowfile.repository.encryption.key.id.Key2=012…​210 would provide an available key Key2.
The simplest configuration is below:
nifi.flowfile.repository.implementation=org.apache.nifi.controller.repository.WriteAheadFlowFileRepository
nifi.flowfile.repository.wal.implementation=org.apache.nifi.wali.EncryptedSequentialAccessWriteAheadLog
nifi.flowfile.repository.encryption.key.provider.implementation=org.apache.nifi.security.kms.StaticKeyProvider
nifi.flowfile.repository.encryption.key.provider.location=
nifi.flowfile.repository.encryption.key.id=Key1
nifi.flowfile.repository.encryption.key=0123456789ABCDEFFEDCBA98765432100123456789ABCDEFFEDCBA9876543210
