OpenId Connect
To enable authentication via OpenId Connect the following properties must be configured in nifi.properties.
Property Name Description
nifi.security.user.oidc.claim.identifying.user
Claim that identifies the user to be logged in; default is email. May need to be requested via the nifi.security.user.oidc.additional.scopes before usage. by the OpenId Connect Provider according to the specification. If this value is HS256, HS384, or HS512, NiFi will attempt to validate HMAC protected tokens using the specified client secret. If this value is none, NiFi will attempt to validate unsecured/plain tokens. Other values for this algorithm will attempt to parse as an RSA or EC algorithm to be used in conjunction with the JSON Web Key (JWK) provided through the jwks_uri in the metadata found at the discovery URL.
nifi.security.user.oidc.discovery.url
The discovery URL for the desired OpenId Connect Provider (http://openid.net/specs/openid-connect-discovery-1_0.html).
nifi.security.user.oidc.connect.timeout
Connect timeout when communicating with the OpenId Connect Provider.
nifi.security.user.oidc.read.timeout
Read timeout when communicating with the OpenId Connect Provider.
nifi.security.user.oidc.client.id
The client id for NiFi after registration with the OpenId Connect Provider.
nifi.security.user.oidc.client.secret
The client secret for NiFi after registration with the OpenId Connect Provider.
nifi.security.user.oidc.preferred.jwsalgorithm
The preferred algorithm for for validating identity tokens. If this value is blank, it will default to RS256 which is required to be supported
Comma separated scopes that are sent to OpenId Connect Provider in addition to openid and email.
