Managing and Monitoring a Cluster
Customize metrics display
Change the way in which a widget displays metrics information, using the Edit icon, if available.
Although not all widgets can be edited, you can customize the way that some of them display metrics by using the Edit icon, if one is displayed.
  1. On the Metrics page, click the edit widget icon
    to customize or remove a widget from the Metrics page.
  2. Click Edit.
    The Customize Widget window appears.
  3. Follow the instructions in Customize Widget to customize widget appearance.
    In this example, you can adjust the thresholds at which the HDFS Capacity bar chart changes color, from green to orange to red.
  4. To save your changes and close the editor, click Apply.
  5. To close the editor without saving any changes, click Cancel.
