When you change a
configuration setting, use Dependent Configurations to confirm other,
related configuration changes.
Change a confguration poperty. As prompted, click Show
Details.
When you change a configuration property value, the Ambari
Stack Advisor captures and recommends changes to all related configuration properties
affected by your original change. Changing a single property, a Smart Configuration, and
other actions; such as adding or deleting a service, host, or ZooKeeper Server, moving a
master, or enabling high availability for a component, all require that you review and
confirm related configuration changes. For example, if you increase the Minimum Container
Size (Memory) setting for YARN, Dependent Configurations lists all
recommended changes that you must review and (optionally) accept.
Types of changes are highlighted in the following colors:
- Value Changes
- Yellow
- Added Properties
- Green
- Deleted properties
- Red
To review and confirm changes to configuration properties:-
In Dependent Configurations, for each listed property review
the summary information.
If the change is acceptable, proceed to review the next property in the list.
If the change is not acceptable, click the check mark in the blue box to the right
of the listed property change.
Clicking the check mark clears the box. Changes for which you clear the box are
not confirmed and will not occur.
After reviewing all listed changes, click OK to confirm that
all marked changes occur.
Restart any components marked for restart to utilize the changes you confirmed.
