Developing Apache Spark Applications
Access Spark SQL through the Spark shell
Use the following steps to acess Spark SQL using the Spark shell.
To read data directly from the file system, construct a SQLContext. For an example that uses SQLContext and the Spark DataFrame API to access a JSON file, see "Using the Spark DataFrame API" in this guide.
To read data by interacting with the Hive Metastore, construct a HiveContext instance (HiveContext extends SQLContext). For an example of the use of HiveContext (instantiated as val sqlContext), see "Accessing ORC Files from Spark" in this guide.
