Running Apache Spark Applications
Set Path Variables for Python
To change the Python executable used by a Livy session, follow the instructions for your version of Python.
pyspark
Livy reads the path from the PYSPARK_PYTHON environment variable (this is the same as PySpark).
  • If Livy is running in local mode, simply set the environment variable (this is the same as PySpark).
  • If the Livy session is running in yarn-cluster mode, setspark.yarn.appMasterEnv.PYSPARK_PYTHON in the SparkConf file, so that the environment variable is passed to the driver.
pyspark3
Livy reads the path from environment variable PYSPARK3_PYTHON.
  • If Livy is running in local mode, simply set the environment variable.
  • If the Livy session is running in yarn-cluster mode, setspark.yarn.appMasterEnv.PYSPARK3_PYTHON in SparkConf file, so that the environment variable is passed to the driver.
