Developing Apache Spark Applications
Using Spark SQL
This section provides information about using Spark SQL.
Using HiveContext, Spark SQL can also read data by interacting with the Hive MetaStore. If you already use Hive, you should use HiveContext; it supports all Hive data formats and user-defined functions (UDFs), and it enables you to have full access to the HiveQL parser. HiveContext extends SQLContext, so HiveContext supports all SQLContext functionality.
  • Interactive access using the Spark shell (see "Accessing Spark SQL through the Spark Shell" in this guide).
  • From an application, operating through one of the following two APIs and the Spark Thrift server:
    • JDBC, using your own Java code or the Beeline JDBC client
    • ODBC, through the Simba ODBC driver
    For more information about JDBC and ODBC access, see "Accessing Spark SQL through JDBC: Prerequisites" and "Accessing Spark SQL through JDBC and ODBC" in this guide.
The following subsections describe how to access Spark SQL through the Spark shell, and through JDBC and ODBC.
