Resuming Flink applications
After updating the Cloudera Streaming Analytics artifacts, you can resume your application by the Flink run command. In case you have stopped your application by creating a savepoint, you must add the savepoint location to the command.
If you had stopped your Flink applications with a savepoint, you must define the path to the savepoint with an additional -s <savepointPath> parameter to the original run command.
flink run -d -ynm YarnApplicationName -s <savepointPath> application.jar
To start your stateless applications or stateful applications with an empty application state, use the original Flink run command.
