Resuming SQL jobs
After upgrading the SQL Stream Builder service in Cloudera Manager, resume your SQL jobs by restarting them using the SQL jobs page of Streaming SQL Console.
  2. Select SQL Jobs on the main menu.
  3. Click on the job you want to restart.
  4. Click Remote job control.
  5. Click Execute.
    If it is needed, you can edit the job by loading it to the SQL Editor using the Load Job, and execute it on the Console page.
