User Defined FunctionsPDF version
Creating User Defined Functions
With SQL Stream Builder, you can create user functions to write powerful functions in JavaScript, that you can use to enhance the functionality of SQL.
User functions can be simple translation functions like Celsius to Fahrenheit, more complex business logic, or even looking up data from external sources. User functions are written in JavaScript. When you write them, you create a library of useful functions.
  2. Click Create Job or select a previous job on the Getting Started page.
    You are redirected to the Console page. The Materialized View button will be available when you add a query to the SQL Editor.
  3. Select Functions from the main menu.
  4. Click New function.
  5. Add a Name to the UDF.
    For example, name the UDF to HELLO_WORLD.
  6. Add a Description to the UDF.
  7. Select the Output and Input data type.
    For example, select STRING.
  8. Paste the JavaScript code to the editor.
    For example:
    // check to see if the card is VISA
    function HELLO_WORLD(card){
        var cardType = "Other";
        if (card.charAt(0) == 4){
          cardType = "Visa";
        return cardType;
    HELLO_WORLD($p0); // this line must exist
  9. Click Create.
  10. Once created, you can use a User Function in your SQL statement:
    For example:
    -- simple usage
    SELECT HELLO_WORLD(card) AS IS_VISA
    FROM ev_sample_fraud;
    -- in the predicate
    SELECT amount, card
    WHERE HELLO_WORLD(card) = "Visa";
