Enabling High Availability for SSB
High Availability for SQL Stream Builder (SSB) SSB can be enabled using a Load Balancer. To enable the Load Balancer for SSB after the SSB service is installed, you need to add the Load Balancer instance to the SSB cluster.
  3. Click Actions > Add Role Instances.
    The Add Role Instances wizard is displayed.
  4. On the Assign Roles page, click Select hosts for Load Balancer.
  5. Select a host and click OK.
    You can add additional SQL Stream Engine and Materialized View Engine servers to boost performance:
    1. Select hosts for SQL Stream Engine.
    2. Select hosts for Materialized View Engine.
    3. Click OK > Continue.
  6. Click Continue.
    The newly added hosts are displayed on the Instances tab.
  7. Select all the newly added hosts.
  8. Click Actions for Selected > Start.
  9. Update the Load Balancer URL and Host.
    1. Click Configuration.
    2. Search for load-balancer url.
    3. Provide the host url where the SSB service is installed.
  10. Restart Cloudera Manager.
    sudo service cloudera-scm-server restart
  11. Access the Streaming SQL Console with Load Balancer.
    3. Click Web UI > SQLStreamBuilder Load Balanced (recommended).
You have a load balanced instance of SSB. You can reach the load balanced instance of Streaming SQL Console from the SSB service page in Cloudera Manager.
