In this example, you will use the Stateless Monitoring Application from the Flink
Tutorials to build your Flink project, submit a Flink job and monitor your Flink application using
the Flink Dashboard in an unsecured environment.
Clone the simple tutorial from git:
git clone https://github.com/cloudera/flink-tutorials.git
Access the simple tutorial folder:
cd flink-tutorials/flink-simple-tutorial
Build your Flink project using maven:
Upload the Flink project to your cluster.
scp <location>/flink-stateful-tutorial-1.2-SNAPSHOT.jar <your_workload_username>@<master_node_FQDN>:.
Password:<your_workload_password>
Run the Flink application:
flink run -d -p 2 -ynm HeapMonitor target/flink-simple-tutorial-1.2-SNAPSHOT.jar
Navigate to , and select the environment where you have created your cluster.
Select the Streaming Analytics cluster.
Click Flink Dashboard from the services.
The Flink Dashboard opens in a new window.
Click Task Manager on the left side menu.
Monitor your Flink application under logs.
