ConnectorsPDF version
SSB fails with missing JAR file error
When creating a custom connector by uploading a JAR file and adding it to Streaming SQL Console, after a period of time the job submission fails when using the newly created connector with a JAR file missing error. This can be solved by changing the location of the storage directory in Cloudera Manager.
The uploaded JAR files are stored under /tmp/ssb-artifacts in SQL Stream Builder (SSB). This temporary folder can be cleaned up periodically by the Operating System (OS), which deletes the JAR files.
  1. Open your cluster in Cloudera Manager.
  3. Select Configuration.
  4. Search for Remote StreamBuilder Artifact Storage Directory in the search bar.
  5. Specify a new directory path for the property where the uploaded SSB artifacts will be stored. By default the path is /tmp/ssb-artifacts.
  6. Optional: Search for Local StreamBuilder Artifact Cache Directory in the search bar. Specify a new directory path for the property where the uploaded SSB artifacts will be chached. By default the path is ssb-artifact-cache.
  7. Click Save.
  8. Restart the SQL Stream Builder service.
