Default ports for Flink and SSB
You need to use the default ports of Flink and SSB when you need to reach or connect to their services. The default port are set in Cloudera Manager, but can be changed if required.
The following table lists the default ports and the corresponding property file names for Flink and SQL Stream Builder (SSB). The ports are set by default in Cloudera Manager. You can change the ports as required using the configuration properties.
Component Service Port Configuration property
Flink Flink Dashboard 18211 historyserver.web.port
SQL Stream Builder Streaming SQL Engine 18121 server.port
Materialized View Engine 18131 server.port
SQL Stream Builder with Load Balancer Streaming SQL Engine 8080 ssb.sse.loadbalancer.server.port
Secured Streaming SQL Engine 8445 ssb.sse.loadbalancer.server.secure.port
Materialized View Engine 8081 ssb.mve.loadbalancer.server.port
Secured Materialized View Engine 8444 ssb.mve.loadbalancer.server.secure.port
For the default port list of the Cloudera Runtime components, see the Ports Used by Cloudera Runtime Components document.
