Input Transforms are a powerful way to clean, modify, and arrange data that is poorly
organized, has changing format, has data that is not needed or otherwise hard to use. With
the Input Transfrom feature of SQL Stream Builder, you can create a javascript function to
transform the data after it has been consumed from a Kafk topic, and before you run SQL
queries on the data.
Select SQL Stream Builder from the list of services.
Click .
Click Create Job or select a previous job on the
Getting Started page.
You are redirected to the Console page.
Open the Kafka table configurations.
You can add the Input Transform to the Kafka table when you create the Kafka
table:
Choose Apache Kafka from the Add table
drop-down.
You can add the Input Transform to an already existing Kafka table:
Select the edit button for the Kafka table you
want to add a transformation.
The Kafka table wizard appears.
Click Data Transformation.
You have the following options to insert your Input Transform:
Add your javascript transformation code to the Data
Transformation box.
Make sure the output of your transform matches the Schema definition
detected or defined for the Kafka table.
Click Install default template and schema.
The Install Default template and schema option fills out the Data
Transformation box with a template that you can use to create the Input
Transform, and matches the schema with the format.
Click Review and Create.
