You can use the Streaming SQL Console to review the status, properties and log of your
SQL Stream jobs executed in SQL Stream Builder. Using the Flink Dashboard, you can also monitor
the Flink job that is submitted when you execute a SQL query.
Using the Streaming SQL Console🔗
When using the SQL Jobs page in Streaming SQL Console to monitor your
SQL jobs, you can review the ID, the Name, the Start time, the State of the submitted jobs,
and the User who submitted the SQL job. When monitoring running jobs, you are also able to
open the Flink Dashboard, and stop the job using the
Stop button under Actions. The Flink
Dashboard link and Stop button are not available for
Stopped Jobs.
Select SQL Jobs from the main menu.
By default, all of the
jobs are displayed on the SQL Jobs page.
Select Running or Stopped.
Click on the job you want to monitor.
The details of the job appear in a new
window.
Select SQL or Properties tab to display
additional details and configurations about the SQL job.
You can also review the
details of the Flink job from the SQL Jobs page.
Click next to Job State of a job on the SQL
Jobs page.
Select Events.
The Events window appears
detailing the Flink job information that can be further filtered based on the log
level settings.
History of SQL queries🔗
You can review and reuse the SQL queries that were previosuly executed on the
History page. When you click on one of the SQL queries, it is
automatically imported to the SQL window for execution. You can filter the SQL queries by
the time they were last run or by the user who run them.
Using the Flink Dashboard🔗
You can also monitor your running SQL jobs using the Flink Dashboard. You can easily reach
the Flink Dashboard from the main menu of Streaming SQL Console.
This site uses cookies and related technologies, as described in our privacy policy, for purposes that may include site operation, analytics, enhanced user experience, or advertising. You may choose to consent to our use of these technologies, or
