COMMENT statement
The COMMENT
statement adds, changes, or removes a comment about a
database, a table, or a column.
You can alternatively use the CREATE
and ALTER
statements to add comments to the objects.
You can view the comment on a database, a table, or a column using the
SHOW
or DESCRIBE
statement.
Syntax:
COMMENT ON DATABASE db_name IS {'comment' | NULL}
COMMENT ON TABLE [db_name.]table_name IS {'comment' | NULL}
COMMENT ON COLUMN [db_name.]table_name.column_name IS {'comment' | NULL}
Parameters:
- db_name: Specify the database name if not for the current database.
NULL
: If given for the comment, removes the existing comment. - The comment string can be up to 256 characters long.
Privileges required:
To add a comment, the ALTER
privilege on the object is required.
To view a comment, the SELECT
, INSERT
, or
REFRESH
Usage notes:
Added in: Impala 3.1 release.
