Data Catalog profiler data testing
You must note about the important information about profiler services.
The Data Catalog profilers are not tested at par with the Hive scale, The following dataset has been validated and works as expected
  • DataHub Master: m5.4xlarge
  • Hive tables: 3000 Hive assets
  • Total Number of assets (including Hive columns, tables, databases) : 1,000,000
  • Total Data Size = 1 GB
  • Partitions on Hive tables: Around 5000 partitions spread across five tables
