Searching for entities using classifications
After you tag entities with classifications, it's very easy to search for the entities.
The Atlas dashboard makes it easy to find entities that you've tagged with classifications: in the left navigation pane, go to the Classification tab and select the classification you want. You can refine your search results by adding criteria on the Search tab.
Refresh       the page to run the animation.
