Known Issues in Flow Management
Learn about the known issues in Flow Management clusters, the impact or changes to the functionality, and the workaround.
- KafkaRecordSink puts multiple records in one message
All the records are sent as a single Kafka message containing an array of records.
For more information, see NIFI-8326.
- Kudu client preventing the creation of new tables using NiFi processors (KUDU-3297)
- There is an issue in the Kudu client preventing the creation of new tables using NiFi
processors. The table needs to exist before NiFi tries to push data into it. You may see
this error when this issue
arises:
Caused by: org.apache.kudu.client.NonRecoverableException: failed to wait for Hive Metastore notification log listener to catch up: failed to retrieve notification log events: failed to open Hive Metastore connection: SASL(-15): mechanism too weak for this user - NiFi Atlas reporting task does not work after data lake upgrade from light to medium
After you upgrade your data lake from light to medium scale, the data lake machine hostname and IP address will change. As the Atlas reporting task uses Atlas and Kafka server hostnames, after the upgrade the wrong hostnames will prevent NiFi to report into Atlas.
- Parameter Context inheritance may be lost during NiFi restart
- Upon restarting NiFi, the inheritance between parameter contexts may be lost under
specific conditions. It is recommended to upgrade to the latest version or to request a
HOTFIX via the support portal.
For more information, see NIFI-10096.
Technical Service Bulletins
- TSB 2022-580: NiFi Processors cannot write to content repository
- If the content repository disk is filled more than 50% (or any other value that is set
in
nifi.propertiesfornifi.content.repository.archive.max.usage.percentage), and if there is no data in the content repository archive, the following warning message can be found in the logs: "Unable to write flowfile content to content repository container default due to archive file size constraints; waiting for archive cleanup". This would block the processors and no more data is processed.This appears to only happen if there is already data in the content repository on startup that needs to be archived, or if the following message is logged: “Found unknown file XYZ in the File System Repository; archiving file”.
- Upstream JIRA
- Knowledge article
- For the latest update on this issue see the corresponding Knowledge article: TSB 2022-580: NiFi Processors cannot write to content repository
- TSB 2022-589: CVE-2022-33140 Apache NiFi ShellUserGroupProvider Vulnerability
- The optional ShellUserGroupProvider in Apache NiFi 1.10.0 to 1.16.2 and Apache NiFi Registry 0.6.0 to 1.16.2 does not neutralize arguments for group resolution commands, allowing injection of operating system commands on Linux and macOS platforms. The ShellUserGroupProvider is not included in the default configuration. Command injection requires ShellUserGroupProvider to be one of the enabled User Group Providers (UGP) in the Authorizers configuration. Command injection also requires an authenticated user with elevated privileges. Apache NiFi requires an authenticated user with authorization to modify access policies in order to execute the command. Apache NiFi Registry requires an authenticated user with authorization to read user groups in order to execute the command. The resolution removes command formatting based on user-provided arguments.
- Knowledge article
- For the latest update on this issue see the corresponding Knowledge article: TSB 2022-589: CVE-2022-33140 Apache NiFi ShellUserGroupProvider Vulnerability
