General Purpose Parsers
The general-purpose parser is primarily designed for lower-velocity topologies or for quickly setting up a temporary parser for a new telemetry.
General purpose parsers are defined using a config file, and you need not recompile the topology to change them. CCP supports two general purpose parsers: Grok and CSV.
Grok parser
The Grok parser class name (parserClassName) is
org.apache.metron,parsers.GrokParser.
The Grok parser supports either one line to parse per incoming message, or incoming messages with multiple log lines, and will produce a json message per line
Grok has the following entries and predefined patterns for
parserConfig:
grokPath -
The path in HDFS (or in the Jar) to the grok statement. By default attempts to load from HDFS, then falls back to the classpath, and finally throws an exception if unable to load a pattern.
patternLabel -
The pattern label to use from the Grok statement.
multiLine- The raw data passed in should be handled as a long with multiple lines, with each
line to be parsed separately. This setting's valid values are
trueorfalse. The default if unset isfalse. When set, the parser will handle multiple lines with successfully processed lines emitted normally, and lines with errors sent to the error topic. -
timestampField -
The field to use for timestamp. If your data does not have a field exactly named "timestamp" this field is required, otherwise the record will not pass validation. If the timestampField is included in the list of timeFields, it will first be parsed using the provided dateFormat.
timeFields -
A list of fields to be treated as time.
dateFormat -
The date format to use to parse the time fields. Default is "yyyy-MM-dd HH:mm:ss.S z".
timezone -
The timezone to use.
UTCis the default.
CSV Parser
The CSV parser class name (parserClassName) is
org.apache.metron.parsers.csv.CSVParser
CSV has the following entries and predefined patterns for
parserConfig:
timestampFormat -
The date format of the timestamp to use. If unspecified, the parser assumes the timestamp is starts at UNIX epoch.
columns -
A map of column names you wish to extract from the CSV to their offsets. For example,
{ 'name' : 1,'profession' : 3}would be a column map for extracting the 2nd and 4th columns from a CSV. -
separator -
The column separator. The default value is ",".
JSON Map Parser
The JSON parser class name (parserClassName) is
org.apache.metron.parsers.csv.JSONMapParser
JSON has the following entries and predefined patterns for
parserConfig:
mapStrategy-
A strategy to indicate how to handle multi-dimensional Maps. This is one of:
DROP -
Drop fields which contain maps
UNFOLD -
Unfold inner maps. So
{ "foo" : { "bar" : 1} }would turn into{"foo.bar" : 1} -
ALLOW -
Allow multidimensional maps
ERROR -
Throw an error when a multidimensional map is encountered
timestamp -
This field is expected to exist and, if it does not, then current time is inserted.
jsonQuery- If this JSON query string is present, the result of the query will be a list of messages. This is useful if you have a JSON document that contains a list or array of messages embedded in it, and you do not have another means of splitting the message.
wrapInEntityArray- This setting's valid values are
trueorfalse. If jsonQuery is present and this flag is present and set to "true", the incoming message will be wrapped in a JSON entity and array. for example: {"name":"value"},{"name2","value2"} will be wrapped as {"message" : [{"name":"value"},{"name2","value2"}]}. This is using the default value for wrapEntityName if that property is not set. wrapEntityName- Sets the name to use when wrapping JSON using wrapInEntityArray. The jsonpQuery should reference this name. Only applicable if jsonpQuery and wrapInEntityArray are specified.
timestamp- A field called timestamp is expected to exist and, if it does not, then current time is inserted.
overrideOriginalString- A boolean setting that will change the way original_string is handled by the parser.
The default value of false uses the global functionality that will append the
unmodified original raw source message as an original_string field. This is the
recommended setting. Setting this option to true will use the individual substrings
returned by the json query as the original_string. For example, a wrapped map such as
{"foo" : [{"name":"value"},{"name2","value2"}]} that uses the jsonpQuery, $.foo, will
result in 2 messages returned. Using the default global original_string strategy, the
messages returned would be:
{ "name" : "value", "original_string" : "{\"foo\" : [{\"name\":\"value\"},{\"name2\",\"value2\"}]}}{ "name2" : "value2", "original_string" : "{\"foo\" : [{\"name\":\"value\"},{\"name2\",\"value2\"}]}}Setting this value to true would result in messages with original_string set as follows:
{ "name" : "value", "original_string" : "{\"name\":\"value\"}}{ "name" : "value", "original_string" : "{\"name2\":\"value2\"}}
Regular Expressions Parser
recordTypeRegex- A regular expression to uniquely identify a record type.
messageHeaderRegex- A regular expression used to extract fields from a message part which is common across all the messages.
convertCamelCaseToUnderScore- If this property is set to true, this parser will automatically convert all the camel case property names to underscore separated. For example, following conversions will automatically happen:
fields- A json list of maps containing a record type to regular expression mapping.
A complete configuration example looks like:
"convertCamelCaseToUnderScore": true,
"recordTypeRegex": "kernel|syslog",
"messageHeaderRegex": "(<syslogPriority>(<=^<)\\d{1,4}(?=>)).*?(<timestamp>(<=>)[A-Za-z] {3}\\s{1,2}\\d{1,2}\\s\\d{1,2}:\\d{1,2}:\\d{1,2}(?=\\s)).*?(<syslogHost>(<=\\s).*?(?=\\s))",
"fields": [
"recordType": "kernel",
"regex": ".*(<eventInfo>(<=\\]|\\w\\:).*?(?=$))"
"recordType": "syslog",
"regex": ".*(<processid>(<=PID\\s=\\s).*?(?=\\sLine)).*(<filePath>(<=64\\s)\/([A-Za-z0-9_-]+\/)+(?=\\w)) (<fileName>.*?(?=\")).*(<eventInfo>(<=\").*?(?=$))"
"messageHeaderRegex": [
"regular expression 1",
"regular expression 2"
Where:
regular expression 1- Valid regular expressions that may have named groups and which would be extracted into fields. This list will be evaluated in order until a matching regular expression is found.
messageHeaderRegex- Run on all the messages. All messages are expected to contain the fields which are
being extracted using the
messageHeaderRegex.messageHeaderRegexis a sort of HCF (highest common factor) in all messages.
recordTypeRegex can be a more advanced regular expression containing named
groups. For example:
"recordTypeRegex": "(<process>(<=\s)\b(kernel|syslog)\b(?=\[|:))"
All the named groups will be extracted as fields.
Though having named group in recordType is completely optional, you might
want to extract named groups in recordType for following reasons:
- Because
recordTyperegular expression is already getting matched and you are paying the price for a regular expression match already, you can extract certain fields as a by product of this match. - The
recordTypefield is probably common across all the messages. So, having it extracted in therecordType(ormessageHeaderRegex) would reduce the overall complexity of regular expressions in the regex field.
regex within a field can also be a list of regular expressions. In this
case all regular expressions in the list will be matched. Once a full match is found,
remaining regular expressions are ignored.
"regex": [ "record type specific regular expression 1",
"record type specific regular expression 2"]
timestamp- Because this parser is a general purpose parser, it will populate the timestamp field with current UTC timestamp. Actual timestamp value can be overridden later using stellar. For example in case of syslog timestamps, you can use following stellar construct to override the timestamp value. Let us say you parsed actual timestamp from the raw log:
