Parser Tuning Example
We'll be using the Bro sensor in this parser tuning example.
We started with a single partition for the inbound Kafka topics and eventually worked our way up to 48 partitions. And we're using the following pending value, as shown below. The default is 'null' which would result in no limit.
storm-bro.config
"topology.max.spout.pending" : 2000
And the following default spout settings. Again, this can be omitted entirely since we are using the defaults.
spout-bro.config
"spout.pollTimeoutMs" : 200,
"spout.maxUncommittedOffsets" : 10000000,
"spout.offsetCommitPeriodMs" : 30000
And we ran our Bro parser topology with the following options. We did not need to fully match the number of Kafka partitions with our parallelism in this case, though you could certainly do so if necessary. Notice that we only needed 1 worker.
/$METRON_HOME/bin/start_parser_topology.sh -k $BROKERLIST -z $ZOOKEEPER -s bro -ksp SASL_PLAINTEXT
-ot enrichments
-e ~metron/.storm/storm-bro.config \
-esc ~/.storm/spout-bro.config \
-sp 24 \
-snt 24 \
-nw 1 \
-pnt 24 \
-pp 24 \
From the usage docs, here are the options we've used.
-e,--extra_topology_options (JSON_FILE) Extra options in the form
of a JSON file with a map
for content.
-esc,--extra_kafka_spout_config (JSON_FILE) Extra spout config options
in the form of a JSON file
with a map for content.
Possible keys are:
retryDelayMaxMs,retryDelay
Multiplier,retryInitialDelayMs,stateUpdateIntervalMs,
bufferSizeBytes,fetchMaxWait,fetchSizeBytes,maxOffswt
Behind,metricsTimeBucketSizeInSecs,socketTimeoutMs
-sp,--spout_p (SPOUT_PARALLELISM_HINT) Spout Parallelism Hint
-snt,--spout_num_tasks (NUM_TASKS) Spout Num Tasks
-nw,--num_workers (NUM_WORKERS) Number of Workers
-pnt,--parser_num_tasks (NUM_TASKS) Parser Num Tasks
-pp,--parser_p (PARALLELISM_HINT) Parser Parallelism Hint
