Apache NiFi Registry admin guidePDF version
AccessPolicyProvider
After you have configured a UserGroupProvider, you must configure an AccessPolicyProvider that will control Access Policies for the identities in the UserGroupProvider.
The default AccessPolicyProvider is the FileAccessPolicyProvider, however, you can develop additional AccessPolicyProvider as extensions. The FileAccessPolicyProvider has the following properties:
Property Name Description
User Group Provider
The identifier for an User Group Provider defined above that will be used to access users and groups for use in the managed access policies.
Authorizations File
The file where the FileAccessPolicyProvider will store policies. By default, authorizations.xml in the conf directory is chosen.
Initial Admin Identity
The identity of an initial admin user that will be granted access to the UI and given the ability to create additional users, groups, and policies. For example, a certificate DN, LDAP identity, or Kerberos principal.
NiFi Identity
The identity of a NiFi instance/node that will be accessing this registry. Each NiFi Identity will be granted permission to proxy user requests, as well as read any bucket to perform synchronization status checks.
NiFi Group Name
The name of the group, whose members are NiFi instance/node identities, that will be accessing this registry. The members of this group will be granted permission to proxy user requests, as well as read any bucket to perform synchronization checks.
