Custom Properties
To configure custom properties for use with NiFi's Expression Language:
  • Create the custom property. Ensure that:
    • Each custom property contains a distinct property value, so that it is not overridden by existing environment properties, system properties, or FlowFile attributes.
    • Each node in a clustered environment is configured with the same custom properties.
  • Update nifi.variable.registry.properties with the location of the custom property file(s):
Property
Description
This is a comma-separated list of file location paths for one or more custom property files.
  • Restart your NiFi instance(s) for the updates to be picked up.
Custom properties can also be configured in the NiFi UI.
