How to install and start NiFi
  • Linux/Unix/macOS
    • Decompress and untar into desired installation directory
    • Make any desired edits in files found under <installdir>/conf
      • At a minimum, we recommend editing the nifi.properties file and entering a password for the nifi.sensitive.props.key (see System Properties below)
    • From the <installdir>/bin directory, execute the following commands by typing ./nifi.sh <command>:
      • start: starts NiFi in the background
      • stop: stops NiFi that is running in the background
      • status: provides the current status of NiFi
      • run: runs NiFi in the foreground and waits for a Ctrl-C to initiate shutdown of NiFi
      • install: installs NiFi as a service that can then be controlled via
        • service nifi start
        • service nifi stop
        • service nifi status
  • Windows
    • Decompress into the desired installation directory
    • Make any desired edits in the files found under <installdir>/conf
    • Navigate to the <installdir>/bin directory
    • Double-click run-nifi.bat. This runs NiFi in the foreground and waits for a Ctrl-C to initiate shutdown of NiFi
    • To see the current status of NiFi, double-click status-nifi.bat
When NiFi first starts up, the following files and directories are created:
  • content_repository
  • database_repository
  • flowfile_repository
  • provenance_repository
  • work directory
  • logs directory
  • Within the conf directory, the flow.xml.gz file is created
See the Security Properties section of this guide for more information about configuring NiFi repositories and configuration files.
