Troubleshooting
If you encounter issues and your cluster does not work as described, investigate the nifi-app.log and nifi-user.log files on the nodes. If needed, you can change the logging level to DEBUG by editing the conf/logback.xml file. Specifically, set the level="DEBUG" in the following line (instead of "INFO"):
    <logger name="org.apache.nifi.web.api.config" level="INFO" additivity="false">
        <appender-ref ref="USER_FILE"/>
    </logger>
