ZooKeeper Properties
NiFi depends on Apache ZooKeeper for determining which node in the cluster should play the role of Primary Node and which node should play the role of Cluster Coordinator. These properties must be configured in order for NiFi to join a cluster.
Property
Description
nifi.zookeeper.connect.string
The Connect String that is needed to connect to Apache ZooKeeper. This is a comma-separated list of hostname:port pairs. For example, localhost:2181,localhost:2182,localhost:2183. This should contain a list of all ZooKeeper instances in the ZooKeeper quorum. This property must be specified to join a cluster and has no default value.
nifi.zookeeper.connect.timeout
How long to wait when connecting to ZooKeeper before considering the connection a failure. The default value is 3 secs.
nifi.zookeeper.session.timeout
How long to wait after losing a connection to ZooKeeper before the session is expired. The default value is 3 secs.
nifi.zookeeper.root.node
The root ZNode that should be used in ZooKeeper. ZooKeeper provides a directory-like structure for storing data. Each 'directory' in this structure is referred to as a ZNode. This denotes the root ZNode, or 'directory', that should be used for storing data. The default value is /root. This is important to set correctly, as which cluster the NiFi instance attempts to join is determined by which ZooKeeper instance it connects to and the ZooKeeper Root Node that is specified.
nifi.zookeeper.client.secure
Whether to acccess ZooKeeper using client TLS.
nifi.zookeeper.security.keystore
Filename of the Keystore containing the private key to use when communicating with ZooKeeper.
nifi.zookeeper.security.keystoreType
Optional. The type of the Keystore. Must be PKCS12, JKS, or PEM. If not specified the type will be determined from the file extension (.p12, .jks, .pem).
nifi.zookeeper.security.keystorePasswd
The password for the Keystore.
nifi.zookeeper.security.truststore
Filename of the Truststore that will be used to verify the ZooKeeper server(s).
nifi.zookeeper.security.truststoreType
Optional. The type of the Truststore. Must be PKCS12, JKS, or PEM. If not specified the type will be determined from the file extension (.p12, .jks, .pem).
nifi.zookeeper.security.truststorePasswd
The password for the Truststore.
nifi.zookeeper.jute.maxbuffer
Maximum buffer size in bytes for packets sent to and received from ZooKeeper. Defaults to 1048575 bytes (0xfffff in hexadecimal) following ZooKeeper default jute.maxbuffer property.
The http://zookeeper.apache.org/doc/current/zookeeperAdmin.html#Unsafe+Options categorizes this property as an unsafe option. Changing this property requires setting jute.maxbuffer on ZooKeeper servers.
