Cluster Node Identities
If you are running NiFi in a clustered environment, you must specify the identities for each node. The authorization policies required for the nodes to communicate are created during startup.
For example, if you are setting up a 2 node cluster with the following DNs for each node:
cn=nifi-1,ou=people,dc=example,dc=com
cn=nifi-2,ou=people,dc=example,dc=com
<authorizers>
    <userGroupProvider>
        <identifier>file-user-group-provider</identifier>
        <class>org.apache.nifi.authorization.FileUserGroupProvider</class>
        <property name="Users File">./conf/users.xml</property>
        <property name="Legacy Authorized Users File"></property>
        <property name="Initial User Identity 1">johnsmith@NIFI.APACHE.ORG</property>
        <property name="Initial User Identity 2">cn=nifi-1,ou=people,dc=example,dc=com</property>
        <property name="Initial User Identity 3">cn=nifi-2,ou=people,dc=example,dc=com</property>
    </userGroupProvider>
    <accessPolicyProvider>
        <identifier>file-access-policy-provider</identifier>
        <class>org.apache.nifi.authorization.FileAccessPolicyProvider</class>
        <property name="User Group Provider">file-user-group-provider</property>
        <property name="Authorizations File">./conf/authorizations.xml</property>
        <property name="Initial Admin Identity">johnsmith@NIFI.APACHE.ORG</property>
        <property name="Node Identity 1">cn=nifi-1,ou=people,dc=example,dc=com</property>
        <property name="Node Identity 2">cn=nifi-2,ou=people,dc=example,dc=com</property>
    </accessPolicyProvider>
    <authorizer>
        <identifier>managed-authorizer</identifier>
        <class>org.apache.nifi.authorization.StandardManagedAuthorizer</class>
        <property name="Access Policy Provider">file-access-policy-provider</property>
    </authorizer>
</authorizers>
Now that initial authorizations have been created, additional users, groups and authorizations can be created and managed in the NiFi UI.
