Homepage
Cloudera DataFlow for Data Hub
7.2.14
(Public Cloud)
Search Documentation
Cloudera
Reference Architectures
Cloudera Public Cloud
Getting Started
Patterns
Preview Features
Data Catalog
Data Engineering
DataFlow
Data Hub
Data Warehouse
Data Warehouse Runtime
Cloudera AI
Management Console
Operational Database
Replication Manager
Cloudera Manager
CDF for Data Hub
Runtime
Cloudera Private Cloud
Data Services
Getting Started
Cloudera Manager
Management Console
Replication Manager
Data Catalog
Data Engineering
Data Warehouse
Cloudera AI
Base
Getting Started
Runtime
Upgrade
Storage
Flow Management
Streaming Analytics
Flow Management Operator
Streaming Analytics Operator
Streams Messaging Operator
Cloudera Manager
Cloudera Manager
Applications
Cloudera Streaming Community Edition
Data Science Workbench
Data Visualization
Edge Management
Observability SaaS
Observability on premises
Workload XM On-Prem
Legacy
Cloudera Enterprise
Flow Management
Stream Processing
HDP
HDF
Streams Messaging Manager
Streams Replication Manager
Getting Started
Patterns
Preview Features
Data Catalog
Data Engineering
DataFlow
Data Hub
Data Warehouse
Cloudera AI
Management Console
Replication Manager
Cloudera Manager
CDF for Data Hub
Runtime
Filter topics
CDF for Data Hub
Release Notes
What's New in Cloudera DataFlow for Data Hub 7.2.14
What's New in Flow Management
What's New in Streams Messaging
Cruise Control Rebase Summary
What's New in Streaming Analytics
Log4j vulnerabilities
Component Support in Cloudera DataFlow for Data Hub 7.2.14
Supported NiFi Extensions
Supported NiFi Processors
Supported NiFi Controller Services
Supported NiFi Reporting Tasks
Components Supported by Partners
Unsupported Features in Cloudera DataFlow for Data Hub 7.2.14
Unsupported Flow Management features
Unsupported Streams Messaging features
Unsupported Streaming Analytics features
Known Issues In Cloudera DataFlow for Data Hub 7.2.14
Known Issues in Flow Management
Known Issues in Streams Messaging
Known Issues in Streaming Analytics
Fixed Issues in Cloudera DataFlow for Data Hub 7.2.14
Fixed Issues in Flow Management
Fixed Issues in Streams Messaging
Fixed Issues in Streaming Analytics
Concepts
Flow Management
Apache NiFi overview
What is Apache NiFi?
The core concepts of NiFi
NiFi Architecture
Performance Expectations and Characteristics of NiFi
High Level Overview of Key NiFi Features
References
Streams Messaging
Apache Kafka overview
Kafka Introduction
Kafka Architecture
Brokers
Topics
Records
Partitions
Record order and assignment
Logs and log segments
Kafka brokers and Zookeeper
Leader positions and in-sync replicas
Kafka FAQ
Basics
Use cases
Schema Registry overview
Examples of interacting with Schema Registry
Schema Registry use cases
Use case 1: Registering and querying a Schema for a Kafka topic
Use case 2: Reading/deserializing and writing/serializing data from and to a Kafka topic
Use case 3: Dataflow management with schema-based routing
Schema Registry component architecture
Schema Registry concepts
Schema entities
Compatibility policies
Streams Messaging Manager overview
Introduction to Streams Messaging Manager
Streams Replication Manager overview
Overview
Key Features
Main Use Cases
Use Case Architectures
Highly Available Kafka Architectures
Active / Stand-by Architecture
Active / Active Architecture
Cross Data Center Replication
Cluster Migration Architectures
On-premise to Cloud and Kafka Version Upgrade
Aggregation for Analytics
Streams Replication Manager Architecture
Streams Replication Manager Driver
Connect workers
Connectors
Task architecture and load-balancing
Driver inter-node coordination
Streams Replication Manager Service
Remote Querying
Understanding Replication Flows
Replication Flows Overview
Remote Topics
Bidirectional Replication Flows
Fan-in and Fan-out Replication Flows
Understanding co-located and external clusters
Understanding SRM properties, their configuration and hierarchy
Cruise Control overview
Kafka cluster load balancing using Cruise Control
How Cruise Control retrieves metrics
How Cruise Control self-healing works
Streaming Analytics
Streaming Analytics overview
Streaming Analytics in Cloudera
What is Apache Flink?
Core Features of Flink
Introduction to SQL Stream Builder
Key features of SSB
Connector support in SSB
SQL Stream Builder architecture
Planning
Planning your Flow Management deployment
Deployment scenarios
Flow Management cluster definitions
Flow Management cluster layout
Planning your Streams Messaging deployment
Data Hub cluster definitions
Streams Messaging cluster layout
Planning your Streaming Analytics deployment
Streaming Analytics deployment scenarios
Streaming Analytics Data Hub cluster definitons
Streaming Analytics cluster layout
How To: Flow Management
Creating your first Flow Management cluster in CDP Public Cloud
Meet the prerequisites
Create your cluster
Give users access to your cluster
Next steps
Authorizing Flow Management cluster access in CDP Public Cloud
Security for Flow Management Clusters and Users in CDP Public Cloud
User Authorization
Authorization workflow
Assigning administrator level permissions
Assigning selective permissions to user
Assign the EnvironmentUser role
Add the user to predefined Ranger access policies
Create a custom access policy
Authorization example
Predefined Ranger Access Policies for Apache NiFi
Predefined Ranger Access Policies for Apache NiFi Registry
Moving data using NiFi site-to-site
Moving data from CDP Private Cloud Base to Public Cloud with NiFi site-to-site
Understand the use case
Prepare your clusters
Set up your network configuration
Configure your truststores
Define your CDP Public Cloud dataflow
Configure Ranger policies for site-to-site communication
Define your CDP Private Cloud Base dataflow
Exchanging data with external systems
Moving data in and out of Snowflake
Pushing data to and moving data from Snowflake using Apache NiFi
Moving data out of Snowflake
Before you begin
Downloading the Snowflake JDBC driver jar file
Adding Snowflake CA certificates to NiFi truststore
Building your dataflow
Creating Controller Services for your dataflow
Configuring your source processor
Configuring your target processor
Confirming your dataflow success
Pushing data into Snowflake
Before you begin
Configuring your Controller Services
Configure your source processor
Next steps
Ingesting data into CDP Public Cloud
Ingesting Data into Apache Kafka in CDP Public Cloud
Ingesting data into Apache Kafka
Build the data flow
Create controller services for your data flow
Configure the processor for your data source
Configure the processor for your data target
Start the data flow
Verify data flow operation
Monitoring end to end latency for Kafka topic
Monitoring your data flow
Next steps
Appendix - Schema example
Ingesting Data into Apache Hive in CDP Public Cloud
Configure the service account
Create IDBroker mapping
Create the Hive target table
Add Ranger policies
Obtain Hive connection details
Build the data flow
Configure the controller services
Start your data flow
Verify your data flow
Next steps
Ingesting Data into Apache HBase in CDP Public Cloud
Ingesting Data into Apache HBase in CDP Cloud
Create the HBase target table
Add Ranger policies
Obtain HBase connection details
Build the data flow
Configure the HBase client service
Next steps
Ingesting data into Apache Kudu in CDP Public Cloud
Ingesting Data into Apache Kudu in CDP Public Cloud
Create the Kudu target table
Build the data flow
Configure the Controller Service
Verify that you can write data to Kudu
Next steps
Ingesting data into Apache Solr in CDP Public Cloud
Create Solr target collection
Build the data flow
Start the data flow
Next steps
Ingesting data into Amazon S3 Buckets
Build the data flow
Set up AWS for your ingest data flow
Configure the processor for merging records
Start the data flow
Next steps
Ingesting data into Azure Data Lake Storage
Build the data flow
Start the data flow
Next steps
Ingesting data into Google Cloud Storage
Build the data flow
Start the data flow
Viewing data lineage in Apache Atlas
Next steps
Ingesting data into cloud object stores with RAZ authorizations
Ingesting data into CDP Object Stores with RAZ authorization
Build the data flow
Configure each object store processor
Set permissions in Ranger
Start the data flow
Next steps
Operating your Flow Management cluster
Scaling your Flow Management cluster
Scaling up or down a NiFi cluster
Scaling up a NiFi cluster
Scaling down a NiFi cluster
Hot loading custom NARs
Configuring Flow Management clusters to hot load custom NARs
Working with flows in Registry using NiFi Toolkit CLI
Exporting or importing data flows with NiFi Toolkit CLI
Connecting to NiFi Registry with NiFi Toolkit CLI
Exporting a flow from NiFi Registry
Importing a new flow into NiFi Registry
Apache NiFi
Using Apache NiFi
Introduction
Browser Support
Unsupported Browsers
Viewing the UI in Variably Sized Browsers
Terminology
NiFi User Interface
Accessing the UI with Multi-Tenant Authorization
Logging In
Building a DataFlow
Adding Components to the Canvas
Component Versions
Sorting and Filtering Components
Changing Component Versions
Understanding Version Dependencies
Configuring a Processor
Settings Tab
Scheduling Tab
Properties Tab
Comments Tab
Additional Help
Configuring a Process Group
General Tab
Controller Services
Parameters
Parameter Contexts
Adding a Parameter to a Parameter Context
Parameters and Expression Language
Assigning a Parameter Context to a Process Group
Referencing Parameters
Accessing Parameters
Using Custom Properties with Expression Language
Variables
Referencing Custom Properties via nifi.properties
Controller Services
Adding Controller Services for Reporting Tasks
Adding Controller Services for Dataflows
Enabling/Disabling Controller Services
Reporting Tasks
Connecting Components
Details Tab
Settings
Changing Configuration and Context Menu Options
Bending Connections
Processor Validation
Site-to-Site
Configure Site-to-Site client NiFi instance
Configure Site-to-Site Server NiFi Instance
Example Dataflow
Command and Control of the DataFlow
Starting a Component
Stopping a Component
Terminating a Component's Tasks
Enabling/Disabling a Component
Remote Process Group Transmission
Individual Port Transmission
Navigating within a DataFlow
Component Linking
Component Alignment
Align Vertically
Align Horizontally
Search Components in DataFlow
Filters
Keywords
Monitoring of DataFlow
Anatomy of a Processor
Anatomy of a Process Group
Anatomy of a Remote Process Group
Queue Interaction
Summary Page
Historical Statistics of a Component
Versioning a DataFlow
Connecting to a NiFi Registry
Version States
Import a Versioned Flow
Start Version Control
Managing Local Changes
Show Local Changes
Revert Local Changes
Commit Local Changes
Change Version
Stop Version Control
Nested Versioned Flows
Parameters in Versioned Flows
Variables in Versioned Flows
Restricted Components in Versioned Flows
Restricted Controller Service Created in Root Process Group
Restricted Controller Service Created in Process Group
Templates
Creating a Template
Importing a Template
Instantiating a Template
Managing Templates
Exporting a Template
Removing a Template
Data Provenance
Provenance Events
Searching for Events
Details of an Event
Replaying a FlowFile
Viewing FlowFile Lineage
Find Parents
Expanding an Event
Write Ahead Provenance Repository
Backwards Compatibility
Older Existing NiFi Version
Bootstrap.conf
System Properties
Repository Encryption
Repository Encryption Protocol Version 1
Encryption Metadata Serialization
Repository Encryption Configuration
Protocol Version Configuration
Key Provider Configuration
Secret Key Generation and Storage using Keytool
Experimental Warning
Other Management Features
Using Apache NiFi Toolkit
Overview
Prerequisites for Running in a Secure Environment
NiFi CLI
Usage
Property/Argument Handling
Security Configuration
Example - Secure NiFi Registry without Proxied-Entity
Example - Secure NiFi Registry with Proxied-Entity
Interactive Usage
Output
Back-Referencing
Adding Commands
Encrypt-Config Tool
Usage
NiFi
NiFi Registry
Protection Schemes
AES_GCM
HASHICORP_VAULT_TRANSIT
HASHICORP_VAULT_KV
AWS_KMS
AWS_SECRETSMANAGER
GCP_KMS
Examples
NiFi
NiFi Registry
Sensitive Property Key Migration
File Manager
Usage
Expected Behavior
Backup
Install
Restore
Flow Analyzer
Usage
Node Manager
Usage
Expected Behavior
Status
Disconnect
Connect
Remove
Notify
Usage
S2S
Usage
TLS Toolkit
Wildcard Certificates
Potential issues with wildcard certificates
Operation Modes
Standalone
Client/Server
Using An Existing Intermediate Certificate Authority (CA)
nifi-cert.pem
nifi-key.key
Signing with Externally-signed CA Certificates
Additional Certificate Commands
ZooKeeper Migrator
Usage
Migrating Between Source and Destination ZooKeepers
ZooKeeper Migration Steps
Adding functionality to Apache NiFi
Introduction
NiFi Components
Processor API
Supporting API
FlowFile
ProcessSession
ProcessContext
PropertyDescriptor
Validator
ValidationContext
PropertyValue
Relationship
StateManager
ProcessorInitializationContext
ComponentLog
AbstractProcessor API
Processor Initialization
Exposing Processor's Relationships
Exposing Processor Properties
Validating Processor Properties
Responding to Changes in Configuration
Performing the Work
When Processors are Triggered
Component Lifecycle
@OnAdded
@OnEnabled
@OnRemoved
@OnScheduled
@OnUnscheduled
@OnStopped
@OnShutdown
Component Notification
@OnPrimaryNodeStateChange
Restricted
State Manager
Scope
Storing and Retrieving State
Unit Tests
Reporting Processor Activity
Documenting a Component
Documenting Properties
Documenting Relationships
Documenting Capability and Keywords
Documenting FlowFile Attribute Interaction
Documenting Related Components
Advanced Documentation
Provenance Events
Common Processor Patterns
Data Ingress
Data Egress
Route Based on Content (One-to-One)
Route Based on Content (One-to-Many)
Route Streams Based on Content (One-to-Many)
Route Based on Attributes
Update Attributes Based on Content
Enrich/Modify Content
Error Handling
Exceptions within the Processor
Exceptions within a callback: IOException, RuntimeException
Penalization vs. Yielding
Session Rollback
General Design Considerations
Consider the User
Cohesion and Reusability
Naming Conventions
Processor Behavior Annotations
Data Buffering
Controller Services
Developing a ControllerService
Interacting with a ControllerService
Reporting Tasks
Developing a Reporting Task
UI Extensions
Custom Processor UIs
Content Viewers
Command Line Tools
Testing
Instantiate TestRunner
Add ControllerServices
Set Property Values
Enqueue FlowFiles
Run the Processor
Validate Output
Mocking External Resources
Additional Testing Capabilities
NiFi Archives (NARs)
Per-Instance ClassLoading
Deprecating a Component
How to contribute to Apache NiFi
Technologies
Where to Start?
Supplying a contribution
Contact Us
Using Apache NiFi Registry
Introduction
Browser Support
Terminology
NiFi Registry User Interface
Logging In
Manage Flows
View a Flow
Sorting & Filtering Flows
Import a Flow
Import New Version of a Flow
Export a Flow Version
Delete a Flow
Manage Buckets
Sorting & Filtering Buckets
Create a Bucket
Delete a Bucket
Delete Multiple Buckets
Edit a Bucket Name
Make a Bucket Publicly Visible
Allow Bundles in a Bucket to be Overwritten
Bucket Policies
Create a Bucket Policy
Delete a Bucket Policy
Manage Users & Groups
Sorting & Filtering Users/Groups
Add a User
Delete a User
Delete Multiple Users
Edit a User Name
Special Privileges
Grant Special Privileges to a User
Manage Groups
Add an Empty Group
Add User to a Group
Create a New Group with Selected Users
Remove a User from a Group
User Window
Group Window
Other Group Level Actions
Manage Bundles
Upload Bundle
Download Bundle
Bundle Coordinates
Bundle Id
Additional Actions
How To: Streams Messaging
Creating your First Streams Messaging cluster in CDP Public Cloud
Creating your first Streams Messaging cluster
Create your cluster
Configure data directories for clusters with custom disk configurations
Next steps
Connecting Kafka clients to CDP Public Cloud clusters
Connecting Kafka clients to Data Hub provisioned clusters
Scaling Streams Messaging clusters
Scaling Kafka brokers
Scaling up Kafka brokers
Scaling down Kafka brokers
Troubleshooting
The downscale operation fails with decommission failed
Scaling Kafka Connect
Scaling up Kafka Connect
Scaling down Kafka Connect
Apache Kafka
Configuring Apache Kafka
Operating system requirements
Performance considerations
Quotas
JBOD
JBOD setup
JBOD Disk migration
Setting user limits for Kafka
Rolling restart checks
Configuring rolling restart checks
Configuring the client configuration used for rolling restart checks
Configuring Kafka ZooKeeper chroot
Rack awareness
Securing Apache Kafka
Channel encryption
Configure Kafka brokers
Configure Kafka clients
Configure Kafka MirrorMaker
Configure Zookeeper TLS/SSL support for Kafka
Authentication
TLS/SSL client authentication
Principal name mapping
Enable Kerberos authentication
Delegation token based authentication
Enable or disable authentication with delegation tokens
Manage individual delegation tokens
Rotate the master key/secret
Client authentication using delegation tokens
Configure clients on a producer or consumer level
Configure clients on an application level
LDAP authentication
PAM authentication
Authorization
Ranger
Enable authorization in Kafka with Ranger
Configure the resource-based Ranger service used for authorization
Governance
Configuring the Atlas hook in Kafka
Inter-broker security
Configuring multiple listeners
Kafka security hardening with Zookeeper ACLs
Restricting access to Kafka metadata in Zookeeper
Unlocking access to Kafka metadata in Zookeeper
Tuning Apache Kafka performance
Handling large messages
Cluster sizing
Sizing estimation based on network and disk message throughput
Choosing the number of partitions for a topic
Broker Tuning
JVM and garbage collection
Network and I/O threads
ISR management
Log cleaner
System Level Broker Tuning
File descriptor limits
Filesystems
Virtual memory handling
Networking parameters
Configure JMX ephemeral ports
Kafka-ZooKeeper performance tuning
Managing Apache Kafka
Management basics
Broker log management
Record management
Broker garbage log collection and log rotation
Client and broker compatibility across Kafka versions
Managing topics across multiple Kafka clusters
Set up MirrorMaker in Cloudera Manager
Settings to avoid data loss
Broker migration
Migrate brokers by modifying broker IDs in meta.properties
Use rsync to copy files from one broker to another
Disk management
Monitoring
Handling disk failures
Disk Replacement
Disk Removal
Reassigning replicas between log directories
Retrieving log directory replica assignment information
Metrics
Building Cloudera Manager charts with Kafka metrics
Essential metrics to monitor
Command Line Tools
Unsupported command line tools
kafka-topics
kafka-configs
kafka-console-producer
kafka-console-consumer
kafka-consumer-groups
kafka-reassign-partitions
Tool usage
Reassignment examples
kafka-log-dirs
zookeeper-security-migration
kafka-delegation-tokens
kafka-*-perf-test
Configuring log levels for command line tools
Understanding the kafka-run-class Bash Script
Developing Apache Kafka applications
Kafka producers
Kafka consumers
Subscribing to a topic
Groups and fetching
Protocol between consumer and broker
Rebalancing partitions
Retries
Kafka clients and ZooKeeper
Java client
Client examples
Simple Java consumer
Simple Java producer
Security examples
.NET client
Client examples
Simple .NET consumer
Simple .NET producer
Performant .NET producer
Security examples
Kafka Streams
Kafka public APIs
Recommendations for client development
Kafka Connect
Kafka Connect Overview [Technical Preview]
Kafka Connect Setup [Technical Preview]
Using Kafka Connect [Technical Preview]
Configuring the Kafka Connect Role
Managing, Deploying and Monitoring Connectors
Writing Kafka data to Ozone with Kafka Connect
Writing data in an unsecured cluster
Writing data in a Kerberos and TLS/SSL enabled cluster
Securing Kafka Connect [Technical Preview]
Configure TLS/SSL Encryption for the Kafka Connect Role
Configure Kerberos Authentication for the Kafka Connect role
Kafka Connect API Security
Connectors [Technical Preview]
Installing Connectors
HTTP Source
JDBC Source
JMS Source
MQTT Source
SFTP Source
Stateless NiFi Source and Sink
Dataflow development best practices for Stateless NiFi
Developing a dataflow for Stateless NiFi
Deploying a dataflow using Stateless NiFi
Syslog TCP Source
Syslog UDP Source
ADLS Sink
Amazon S3 Sink
Configuration example
HDFS Sink
Configuration example for writing data to HDFS
Configuration example for writing data to Ozone FS
HTTP SInk
JDBC Sink
Kudu Sink
S3 Sink
Schema Registry
Integrating with Schema Registry
Integrating with NiFi
Understand the NiFi record based processors and controller services
Set up the HortonworksSchemaRegistry controller service
Adding and configuring record reader and writer controller services
Using record-enabled processors
Integrating with Kafka
Integrate Kafka and Schema Registry using NiFi processors
Integrating with Atlas
Improve performance in Schema Registry
Using Schema Registry
Adding a new schema
Querying a schema
Evolving a schema
Deleting a schema
Importing Confluent Schema Registry schemas into Cloudera Schema Registry
Importing and exporting schemas
Exporting schemas
Importing schemas
ID ranges in Schema Registry
Setting a Schema Registry ID range
Securing Schema Registry
Schema Registry authorization through Ranger access policies
Pre-defined access policies for Schema Registry
Add the user or group to a pre-defined access policy
TLS encryption
TLS certificate requirements and recommendations
Configure TLS encryption manually for Schema Registry
Schema Registry TLS properties
Customizing the Kerberos principal for Schema Registry
Monitoring Kafka clusters
Monitoring Kafka producers
Monitoring Kafka topics
Monitoring Kafka brokers
Monitoring Kafka consumers
Monitoring lineage information
Managing alert policies
Introduction to alert policies in Streams Messaging Manager
Component types and metrics for alert policies
Notifiers
Managing alert policies and notifiers in SMM
Creating a notifier
Updating a notifier
Deleting a notifier
Creating an alert policy
Updating an alert policy
Enabling an alert policy
Disabling an alert policy
Deleting an alert policy
Managing Kafka topics
Creating a Kafka topic
Modifying a Kafka topic
Deleting a Kafka topic
Monitoring end-to-end latency
End to end latency overview
Granularity of metrics for end-to-end latency
Enabling interceptors
End to end latency use case
Monitoring Kafka cluster replications using Streams Messaging Manager
Introduction to monitoring Kafka cluster replications in SMM
Configuring SMM for monitoring Kafka cluster replications
Viewing Kafka cluster replication details
Searching Kafka cluster replications by source
Monitoring Kafka cluster replications by quick ranges
Monitoring status of the clusters to be replicated
Monitoring topics to be replicated
Searching by topic name
Monitoring throughput for cluster replication
Monitoring replication latency for cluster replication
Monitoring checkpoint latency for cluster replication
Monitoring replication throughput and latency by values
Monitoring Kafka Connect using Streams Messaging Manager
Introduction to Kafka Connect
Default view of Kafka Connect in the SMM UI
Creating a connector using Kafka Connect in SMM
Modifying a connector using Kafka Connect in SMM
Deleting a connector using Kafka Connect in SMM
Monitoring connectors using Kafka Connect in SMM
Monitoring connector profile using Kafka Connect in SMM
Monitoring connector settings using Kafka Connect in SMM
Monitoring cluster profile using Kafka Connect in SMM
Securing Streams Messaging Manager
Verifying the setup
Planning for Streams Replication Manager
Streams Replication Manager requirements
Recommended deployment architecture
Configuring Streams Replication Manager
Enable high availability
Defining and adding clusters for replication
Defining external Kafka clusters
Defining co-located Kafka clusters using a service dependency
Defining co-located Kafka clusters using Kafka credentials
Adding clusters to SRM's configuration
Configuring replications
Configuring the driver role target clusters
Configuring the service role target cluster
Configuring properties not exposed in Cloudera Manager
Configuring replication specific REST servers
Configuring Remote Querying
Enabling Remote Querying
Configuring the advertised information of the SRM Service role
Configuring SRM Driver retry behaviour
Configuring SRM Driver heartbeat emission
Configuring automatic group offset synchronization
New topic and consumer group discovery
Configuration examples
Bidirectional replication example of two active clusters
Cross data center replication example of multiple clusters
Using Streams Replication Manager
SRM Command Line Tools
srm-control
Configuring srm-control
Configuring the SRM client's secure storage
Configuring TLS/SSL properties
Configuring Kerberos properties
Configuring properties for non-Kerberos authentication mechanisms
Setting the secure storage password as an environment variable
Topics and Groups Subcommand
Offsets Subcommand
Monitoring Replication with Streams Messaging Manager
Replicating Data
How to Set up Failover and Failback
Configure SRM for Failover and Failback
Migrating Consumer Groups Between Clusters
Securing Streams Replication Manager
Security overview
Enabling TLS/SSL for the SRM service
Enabling Kerberos for the SRM service
Configuring Basic Authentication for the SRM Service
Enabling Basic Authentication for the SRM Service
Configuring Basic Authentication for Remote Querying
SRM security example
Use cases for Streams Replication Manager in CDP Public Cloud
Using SRM in CDP Public Cloud overview
Replicating data from PvC Base to Data Hub with on-prem SRM
Replicating data from PvC Base to Data Hub with cloud SRM
Replicate data between Data Hub clusters with cloud SRM
Cruise Control
Configuring Cruise Control
Configuring capacity estimations and goals
Configuring Metrics Reporter in Cruise Control
Adding self-healing goals to Cruise Control in Cloudera Manager
Securing Cruise Control
Enable security for Cruise Control
Managing Cruise Control
Rebalancing with Cruise Control
Cruise Control REST API endpoints
How To: Streaming Analytics
Creating your first Streaming Analytics Cluster in CDP Public Cloud
Creating your first Streaming Analytics cluster
Create your cluster
Next steps
Analyzing data with Apache Flink
Analyzing your data with Kafka
Prepare your environment
Assign resource roles
Set workload password
Create your streaming clusters
Set Ranger policies
Grant permission for the ATLAS_HOOK topic
Retrieve and upload keytab file
Create Atlas entity type definitions
Running your Flink application
Job monitoring with Flink Dashboard
Metadata governance with Atlas
Analyzing your data with Kudu
Analyzing your data with HBase
Querying data with SQL Stream Builder
Assigning resource roles
Creating IDBroker mapping
Setting workload password
Creating Streaming Analytics cluster
Configuring Ranger policies for SSB
Retrieving keytab file
Uploading and unlocking your keytab in SSB
Running a simple SQL job
Creating Kafka tables in SSB
Adding Kafka as Data Provider
Creating Kafka tables using Console wizard
Configuring Kafka tables
Creating Input Transforms
Creating Kafka tables using Templates
Integration with Kafka
Creating tables with Flink SQL in SSB
Adding catalogs as Data Provider
Adding Schema Registry as Catalog
Adding Kudu as Catalog
Adding Hive as Catalog
Adding Custom Catalogs
Creating Flink tables using Templates
Creating Webhook tables
Running SQL Stream jobs
Flink SQL Overview
Flink DDL
Managing time in SSB
Flink DML
Flink Queries
Other supported statements
SQL Examples
Enriching streaming data with join
Joining streaming and bounded tables
Example: joining Kafka and Kudu tables
Using Materialized Views in SQL Stream Builder
Introduction to Materialized Views
Creating Materialized Views
Using Dynamic Materialized View Endpoints
Configuring Materialized View database information
Using SQL Stream Builder with Cloudera Data Visualization
Apache Flink
Application development
Flink application structure
Source, operator and sink in DataStream API
Flink application example
Testing and validating Flink applications
Flink Project Template
Configuring Flink applications
Setting parallelism and max parallelism
Configuring Flink application resources
Configuring RocksDB state backend
Enabling checkpoints for Flink applications
DataStream connectors
HBase sink with Flink
Kafka with Flink
Schema Registry with Flink
ClouderaRegistryKafkaSerializationSchema
ClouderaRegistryKafkaDeserializationSchema
Kafka Metrics Reporter
Kudu with Flink
Job lifecycle
Running a Flink job
Using Flink CLI
Enabling savepoints for Flink applications
Monitoring
Flink Dashboard
Streams Messaging Manager integration
Enabling Flink DEBUG logging
Governance
Flink metadata collection using Atlas
Atlas entities in Flink metadata collection
Migrating Flink jobs
Migrating Flink jobs without state
Migrating stateful Flink jobs
Updating Flink job dependencies
SQL Stream Builder
Managing teams in Streaming SQL Console
Using the Streaming SQL Console
Console Page
Compose Tab
Tables Tab
Functions Tab
History Tab
SQL Jobs Tab
Data Providers Page
Materialized Views Page
Registering Data Providers in SSB
Using auto discovery of services
Setting up the auto discovery
Using the auto discovery on Streaming SQL Console
Managing registered Data Providers
Connectors in SSB
Kafka connectors
CDC connectors
JDBC connector
Filesystem connector
Datagen connector
Faker connector
Blackhole connector
Managing connectors and data formats
Adding new connectors
Adding data formats
Concept of tables in SSB
Job Lifecycle
Configuring SQL job settings
Adjusting logging configuration in Advanced Settings
Stopping, restarting and editing SQL jobs
Sampling data for a running job
Managing session for SQL jobs
Executing SQL jobs in production mode
Migrating SQL jobs
Using SQL Stream Builder REST API
Creating User Defined Functions
Adding Java to the Functions language option
Monitoring SQL Stream jobs
SQL Syntax Guide
Reference
Apache NiFi REST API reference
Apache NiFi REST API Reference
Apache NiFi Record Path reference
Overview
Structure of a RecordPath
Child Operator
Descendant Operator
Filters
Function Usage
Arrays
Maps
Predicates
Functions
Standalone Functions
substring
substringAfter
substringAfterLast
substringBefore
substringBeforeLast
replace
replaceRegex
concat
fieldName
toDate
toString
toBytes
coalesce
format
trim
toUpperCase
toLowerCase
base64Encode
base64Decode
escapeJson
unescapeJson
hash
padLeft
padRight
uuid5
Filter Functions
contains
matchesRegex
startsWith
endsWith
not
isEmpty
isBlank
Apache NiFi Expression Language guide
Overview
Structure of a NiFi Expression
Expression Language Hierarchy
Expression Language in the Application
Escaping Expression Language
Expression Language Editor
Functions
Data Types
Boolean Logic
isNull
notNull
isEmpty
equals
equalsIgnoreCase
gt
ge
lt
le
and
or
not
ifElse
String Manipulation
toUpper
toLower
trim
substring
substringBefore
substringBeforeLast
substringAfter
substringAfterLast
getDelimitedField
append
prepend
replace
replaceFirst
replaceAll
padLeft
padRight
replaceNull
replaceEmpty
length
evaluateELString
repeat
Encode/Decode Functions
escapeJson
escapeXml
escapeCsv
escapeHtml3
escapeHtml4
unescapeJson
unescapeXml
unescapeCsv
unescapeHtml3
unescapeHtml4
urlEncode
urlDecode
base64Encode
base64Decode
UUID3
UUID5
hash
Searching
startsWith
endsWith
contains
in
find
matches
indexOf
lastIndexOf
jsonPath
jsonPathDelete
jsonPathAdd
jsonPathSet
jsonPathPut
Mathematical Operations and Numeric Manipulation
plus
minus
multiply
divide
mod
toRadix
fromRadix
random
math
Date Manipulation
format
toDate
now
Type Coercion
toString
toNumber
toDecimal
Subjectless Functions
ip
hostname
UUID
nextInt
literal
getStateValue
thread
Evaluating Multiple Attributes
anyAttribute
allAttributes
anyMatchingAttribute
allMatchingAttributes
anyDelineatedValue
allDelineatedValues
join
count
Apache NiFi admin guide
System Requirements
How to install and start NiFi
Port Configuration
NiFi
Embedded ZooKeeper
Configuration Best Practices
Recommended Antivirus Exclusions
TLS Generation Toolkit
TLS Cipher Suites
User Authentication
Single User
Lightweight Directory Access Protocol (LDAP)
Kerberos
OpenId Connect
SAML
Apache Knox
JSON Web Tokens
Authorizer Configuration
Authorizers.xml Setup
FileUserGroupProvider
LdapUserGroupProvider
ShellUserGroupProvider
AzureGraphUserGroupProvider
Composite Implementations
FileAccessPolicyProvider
StandardManagedAuthorizer
FileAuthorizer
Initial Admin Identity (New NiFi Instance)
Legacy Authorized Users (NiFi Instance Upgrade)
Cluster Node Identities
Configuring Users & Access Policies
Creating Users and Groups
Access Policies
Viewing Policies on Users
Access Policy Configuration Examples
Key Derivation Functions
NiFi Legacy KDF
OpenSSL PKCS#5 v1.5 EVP_BytesToKey
Bcrypt
Scrypt
PBKDF2
None
Argon2
Salt and IV Encoding
NiFi Legacy
Bcrypt, Scrypt, PBKDF2, Argon2
Java Cryptography Extension (JCE) Limited Strength Jurisdiction Policies
Allow Insecure Cryptographic Modes
Encrypted Passwords in Flows
Encrypted Passwords in Configuration Files
HashiCorp Vault providers
Required properties
Optional properties
AWS KMS provider
Required properties
Optional properties
AWS Secrets Manager provider
Optional properties
Azure Key Vault Key Provider
Required properties
Azure Key Vault Secret Provider
Required properties
Google Cloud KMS provider
Required properties
Property Context Mapping
Example
NiFi Toolkit Administrative Tools
Clustering Configuration
Zero-Leader Clustering
Why Cluster?
Terminology
Communication within the Cluster
Managing Nodes
Disconnect Nodes
Offload Nodes
Delete Nodes
Decommission Nodes
NiFi CLI Node Commands
Flow Election
Basic Cluster Setup
Cluster Firewall Configuration
Troubleshooting
State Management
Configuring State Providers
Embedded ZooKeeper Server
ZooKeeper Access Control
Securing ZooKeeper with Kerberos
Kerberizing Embedded ZooKeeper Server
Kerberizing NiFi's ZooKeeper Client
Troubleshooting Kerberos Configuration
Securing ZooKeeper with TLS
Embedded ZooKeeper with TLS
ZooKeeper Migrator
Bootstrap Properties
Notification Services
Email Notification Service
HTTP Notification Service
Proxy Configuration
Kerberos Service
Notes
Analytics Framework
System Properties
Upgrade Recommendations
Core Properties
State Management
H2 Settings
FlowFile Repository
Write Ahead FlowFile Repository
Encrypted Write Ahead FlowFile Repository Properties
Volatile FlowFile Repository
RocksDB FlowFile Repository
Swap Management
Content Repository
File System Content Repository Properties
Encrypted File System Content Repository Properties
Volatile Content Repository Properties
Write Ahead Provenance Repository Properties
Encrypted Write Ahead Provenance Repository Properties
Persistent Provenance Repository Properties
Volatile Provenance Repository Properties
Status History Repository
In memory repository
Persistent repository
Site to Site Properties
Site to Site Routing Properties for Reverse Proxies
Site to Site protocol sequence
Reverse Proxy Configurations
Site to Site and Reverse Proxy Examples
Web Properties
Security Properties
Identity Mapping Properties
Cluster Common Properties
Cluster Node Properties
ZooKeeper Properties
Kerberos Properties
Analytics Properties
Runtime Monitoring Properties
Custom Properties
Upgrading NiFi
Preserve Custom Processors
Preserve Modified NARs
Clear Activity and Shutdown Existing NiFi
Install the new NiFi Version
Update the Configuration Files for Your New NiFi Installation
Migrating a Flow with Sensitive Properties
Updating the Sensitive Properties Key
Start New NiFi
Processor Locations
Available Configuration Options
Installing Custom Processors
Autoloading Custom Processors
NAR Providers
HDFS NAR Provider
NiFi diagnostics
Automatic diagnostics on restart and shutdown
Apache NiFi Registry admin guide
System Requirements
How to install and start NiFi Registry
User Authentication
Kerberos
Authorization
UserGroupProvider
Initial Admin Identity (New NiFi Registry Instance)
Access Policies
Bucket Policies
Special Privilege Policies
Encrypt-Config Tool
Proxy Configuration
Kerberos Service
Notes
System Properties
Web Properties
Security Properties
Providers Properties
Alias Properties
Database Properties
Extension Directories
Kerberos Properties
Metadata Database
H2
Postgres
MySQL
Schema Differences & Limitations
Persistence Providers
Flow Persistence Providers
FileSystemFlowPersistenceProvider
GitFlowPersistenceProvider
DatabaseFlowPersistenceProvider
Switching from other Flow Persistence Provider
Data model version of serialized Flow snapshots
Bundle Persistence Providers
FileSystemBundlePersistenceProvider
S3BundlePersistenceProvider
Event Hooks
Shared Event Hook Properties
ScriptEventHookProvider
LoggingEventHookProvider
URL Aliasing
Backup & Recovery
Metadata Database
Flow Persistence
Bundle Persistence
Configuration Files
Apache NiFi Registry REST API reference
1. Overview
1.1. Version information
1.2. Contact information
1.3. License information
1.4. URI scheme
1.5. Tags
2. Security
2.1. Authorization
2.2. BasicAuth
3. Resources
3.1. Access
3.1.1. Get access status
3.1.2. Performs a logout for other providers that have been issued a JWT.
3.1.3. Redirect/callback URI for processing the result of the OpenId Connect login sequence.
3.1.4. Retrieves a JWT following a successful login sequence using the configured OpenId Connect provider.
3.1.5. Performs a logout in the OpenId Provider.
3.1.6. Initiates a request to authenticate through the configured OpenId Connect provider.
3.1.7. Create token trying all providers
3.1.8. Create token using identity provider
3.1.9. Test identity provider
3.1.10. Get identity provider usage
3.1.11. Create token using kerberos
3.1.12. Create token using basic auth
3.2. Bucket Bundles
3.2.1. Get extension bundles by bucket
3.2.2. Create extension bundle version
3.3. Bucket Flows
3.3.1. Create flow
3.3.2. Get bucket flows
3.3.3. Get bucket flow
3.3.4. Update bucket flow
3.3.5. Delete bucket flow
3.3.6. Get bucket flow diff
3.3.7. Create flow version
3.3.8. Get bucket flow versions
3.3.9. Import flow version
3.3.10. Get latest bucket flow version content
3.3.11. Get latest bucket flow version metadata
3.3.12. Get bucket flow version
3.3.13. Exports specified bucket flow version content
3.4. Buckets
3.4.1. Create bucket
3.4.2. Get all buckets
3.4.3. Get bucket fields
3.4.4. Get bucket
3.4.5. Update bucket
3.4.6. Delete bucket
3.5. Bundles
3.5.1. Get all bundles
3.5.2. Get all bundle versions
3.5.3. Get bundle
3.5.4. Delete bundle
3.5.5. Get bundle versions
3.5.6. Get bundle version
3.5.7. Delete bundle version
3.5.8. Get bundle version content
3.5.9. Get bundle version extensions
3.5.10. Get bundle version extension
3.5.11. Get bundle version extension docs
3.5.12. Get bundle version extension docs details
3.6. Config
3.6.1. Get configration
3.7. Extension Repository
3.7.1. Get extension repo buckets
3.7.2. Get extension repo groups
3.7.3. Get extension repo artifacts
3.7.4. Get extension repo versions
3.7.5. Get extension repo version
3.7.6. Get extension repo version content
3.7.7. Get extension repo extensions
3.7.8. Get extension repo extension
3.7.9. Get extension repo extension docs
3.7.10. Get extension repo extension details
3.7.11. Get extension repo version checksum
3.7.12. Get global extension repo version checksum
3.8. Extensions
3.8.1. Get all extensions
3.8.2. Get extensions providing service API
3.8.3. Get extension tags
3.9. Flows
3.9.1. Get flow fields
3.9.2. Get flow
3.9.3. Get flow versions
3.9.4. Get latest flow version
3.9.5. Get latest flow version metadata
3.9.6. Get flow version
3.10. Items
3.10.1. Get all items
3.10.2. Get item fields
3.10.3. Get bucket items
3.11. Policies
3.11.1. Create access policy
3.11.2. Get all access policies
3.11.3. Get available resources
3.11.4. Get access policy for resource
3.11.5. Get access policy
3.11.6. Update access policy
3.11.7. Delete access policy
3.12. Tenants
3.12.1. Create user group
3.12.2. Get user groups
3.12.3. Get user group
3.12.4. Update user group
3.12.5. Delete user group
3.12.6. Create user
3.12.7. Get all users
3.12.8. Get user
3.12.9. Update user
3.12.10. Delete user
4. Definitions
4.1. AccessPolicy
4.2. AccessPolicySummary
4.3. AllowableValue
4.4. Attribute
4.5. BatchSize
4.6. Bucket
4.7. BucketItem
4.8. BuildInfo
4.9. Bundle
4.10. BundleInfo
4.11. BundleVersion
4.12. BundleVersionDependency
4.13. BundleVersionMetadata
4.14. ComponentDifference
4.15. ComponentDifferenceGroup
4.16. ConnectableComponent
4.17. ControllerServiceAPI
4.18. ControllerServiceDefinition
4.19. CurrentUser
4.20. DeprecationNotice
4.21. DynamicProperty
4.22. DynamicRelationship
4.23. Extension
4.24. ExtensionBundle
4.25. ExtensionFilterParams
4.26. ExtensionMetadata
4.27. ExtensionMetadataContainer
4.28. ExtensionRepoArtifact
4.29. ExtensionRepoBucket
4.30. ExtensionRepoGroup
4.31. ExtensionRepoVersion
4.32. ExtensionRepoVersionSummary
4.33. ExternalControllerServiceReference
4.34. Fields
4.35. JaxbLink
4.36. Permissions
4.37. Position
4.38. Property
4.39. ProvidedServiceAPI
4.40. RegistryConfiguration
4.41. Relationship
4.42. Resource
4.43. ResourcePermissions
4.44. Restricted
4.45. Restriction
4.46. RevisionInfo
4.47. Stateful
4.48. SystemResourceConsideration
4.49. TagCount
4.50. Tenant
4.51. User
4.52. UserGroup
4.53. VersionedConnection
4.54. VersionedControllerService
4.55. VersionedFlow
4.56. VersionedFlowCoordinates
4.57. VersionedFlowDifference
4.58. VersionedFlowSnapshot
4.59. VersionedFlowSnapshotMetadata
4.60. VersionedFunnel
4.61. VersionedLabel
4.62. VersionedParameter
4.63. VersionedParameterContext
4.64. VersionedPort
4.65. VersionedProcessGroup
4.66. VersionedProcessor
4.67. VersionedPropertyDescriptor
4.68. VersionedRemoteGroupPort
4.69. VersionedRemoteProcessGroup
4.70. VersionedResourceDefinition
Kafka Connect Connector Reference
HTTP Source properties reference
JDBC Source properties reference
JMS Source properties reference
MQTT Source properties reference
SFTP Source properties reference
Stateless NiFi Source properties reference
Syslog TCP Source properties reference
Syslog UDP Source properties reference
ADLS Sink properties reference
Amazon S3 Sink properties reference
HDFS Sink properties reference
HTTP Sink properties reference
JDBC Sink properties reference
Kudu Sink properties reference
Stateless NiFi Sink properties reference
Schema Registry REST API reference
Streams Messaging Manager REST API reference
Streams Replication Manager reference
srm-control Options Reference
Configuration Properties Reference for Properties not Available in Cloudera Manager
Kafka credentials property reference
SRM Service data traffic reference
Streams Replication Manager REST API reference
Cruise Control REST API reference
SQL Stream Builder REST API reference
Learning & Training
Getting started with Streams Messaging clusters in CDP Public Cloud
Introducing streams messaging cluster on CDP Public Cloud
Meet the prerequisites to create streams messaging cluster
Creating Machine User
Granting Machine User access to environment
Creating Kafka topic
Create Ranger policies for Machine User account
Create topic policy
Create consumer group policy
Produce data to Kafka topic
Connecting to Kafka host
Configuring LDAP authentication
Producing data to Kafka topic
Consuming data from Kafka topic
Use Kerberos authentication
Kerberos authentication using the ticket cache
Kerberos authentication using a keytab
Monitoring Kafka activity in Streams Messaging Manager
Use Schema Registry
Gather configuration information
Finding list of brokers
Finding Schema Registry endpoint
Creating TLS truststore
Defining Schema Registry access policies
Producing data in Avro format
Checking schema registration
Checking producer activity
Consuming data from Kafka topics using stored schemas
Monitor end-to-end latency
Setting up authorization policies
Enabling end-to-end latency monitoring
Evolve your schema
Reconfiguring the Kafka consumer
Reconfiguring the Kafka producer
What to do next
Getting started with Apache NiFi Registry
Who is This Guide For?
Terminology Used in This Guide
Downloading and Installing NiFi Registry
Starting NiFi Registry
For Linux/Unix/Mac OS X users
Installing as a Service
I Started NiFi Registry. Now What?
Create a Bucket
Connect NiFi to the Registry
Start Version Control on a Process Group
Save Changes to a Versioned Flow
Where To Go For More Information
.NET client
1. Overview
1.4. URI scheme
1.5. Tags
2. Security
2.1. Authorization
2.2. BasicAuth
3. Resources
3.1. Access
3.10. Items
3.11. Policies
3.12. Tenants
3.12.6. Create user
3.12.8. Get user
3.12.9. Update user
3.2. Bucket Bundles
3.3. Bucket Flows
3.3.1. Create flow
3.4. Buckets
3.4.4. Get bucket
3.5. Bundles
3.5.3. Get bundle
3.6. Config
3.8. Extensions
3.9. Flows
3.9.2. Get flow
4. Definitions
4.1. AccessPolicy
4.10. BundleInfo
4.11. BundleVersion
4.19. CurrentUser
4.23. Extension
4.3. AllowableValue
4.34. Fields
4.35. JaxbLink
4.36. Permissions
4.37. Position
4.38. Property
4.4. Attribute
4.41. Relationship
4.42. Resource
4.44. Restricted
4.45. Restriction
4.46. RevisionInfo
4.47. Stateful
4.49. TagCount
4.5. BatchSize
4.50. Tenant
4.51. User
4.52. UserGroup
4.55. VersionedFlow
4.6. Bucket
4.64. VersionedPort
4.7. BucketItem
4.8. BuildInfo
4.9. Bundle
@OnAdded
@OnEnabled
@OnRemoved
@OnScheduled
@OnShutdown
@OnStopped
@OnUnscheduled
Access Policies
Access Policies
Add a User
Add an Empty Group
Add Ranger policies
Add Ranger policies
Add User to a Group
Adding a new schema
Adding Commands
Adding data formats
Additional Actions
Additional Help
ADLS Sink
AES_GCM
Alias Properties
Align Horizontally
Align Vertically
allAttributes
allDelineatedValues
Amazon S3 Sink
Analytics Framework
and
anyAttribute
anyDelineatedValue
Apache Flink
Apache Kafka
Apache Knox
Apache NiFi
append
Argon2
Arrays
Authentication
Authorization
Authorization
AWS KMS provider
AWS_KMS
AWS_SECRETSMANAGER
Back-Referencing
Backup
Backup & Recovery
base64Decode
base64Decode
base64Encode
base64Encode
Basic Cluster Setup
Basics
Bcrypt
Before you begin
Before you begin
Bending Connections
Blackhole connector
Boolean Logic
Bootstrap.conf
Broker migration
Broker Tuning
Brokers
Browser Support
Browser Support
Bucket Policies
Bucket Policies
Build the data flow
Build the data flow
Build the data flow
Build the data flow
Build the data flow
Build the data flow
Build the data flow
Build the data flow
Build the data flow
Building a DataFlow
Bundle Coordinates
Bundle Id
Bundle Persistence
CDC connectors
CDF for Data Hub
Change Version
Channel encryption
Child Operator
Client examples
Client examples
Client/Server
Cluster sizing
coalesce
Command Line Tools
Command Line Tools
Comments Tab
Component Alignment
Component Lifecycle
Component Linking
Component Versions
ComponentLog
Compose Tab
concat
Configuration Files
Connect
Connect workers
Connectors
Connectors in SSB
Consider the User
Console Page
Contact Us
contains
contains
Content Repository
Content Viewers
Controller Services
Controller Services
Controller Services
Core Properties
count
Create a Bucket
Create a Bucket
Create topic policy
Create your cluster
Create your cluster
Create your cluster
Creating a notifier
Creating a Template
Cruise Control
Custom Properties
Data Buffering
Data Egress
Data Ingress
Data Provenance
Data Providers Page
Data Types
Database Properties
Datagen connector
Date Manipulation
Decommission Nodes
Delete a Bucket
Delete a Flow
Delete a User
Delete Nodes
Deleting a notifier
Deleting a schema
Descendant Operator
Details of an Event
Details Tab
Disconnect
Disconnect Nodes
Disk management
Disk Removal
Disk Replacement
divide
Download Bundle
Edit a Bucket Name
Edit a User Name
Embedded ZooKeeper
Encrypt-Config Tool
Encrypt-Config Tool
endsWith
endsWith
Enqueue FlowFiles
equals
equalsIgnoreCase
Error Handling
escapeCsv
escapeHtml3
escapeHtml4
escapeJson
escapeJson
escapeXml
evaluateELString
Event Hooks
Evolve your schema
Evolving a schema
Example
Example Dataflow
Examples
Expanding an Event
Expected Behavior
Expected Behavior
Exporting schemas
Faker connector
fieldName
File Manager
FileAuthorizer
Filesystems
Filter Functions
Filters
Filters
find
Find Parents
Flink Dashboard
Flink DDL
Flink DML
Flink Queries
Flink SQL Overview
Flow Analyzer
Flow Election
Flow Management
Flow Persistence
FlowFile
FlowFile Repository
format
format
fromRadix
Function Usage
Functions
Functions
Functions Tab
GCP_KMS
ge
General Tab
getDelimitedField
getStateValue
Governance
Governance
Group Window
Groups and fetching
gt
H2
H2 Settings
hash
hash
HASHICORP_VAULT_KV
HDFS NAR Provider
HDFS Sink
History Tab
hostname
HTTP SInk
HTTP Source
ifElse
Import a Flow
Importing schemas
in
indexOf
Install
Interactive Usage
Introduction
Introduction
Introduction
ip
isBlank
isEmpty
isEmpty
isNull
ISR management
Java client
JBOD
JBOD Disk migration
JBOD setup
JDBC connector
JDBC Sink
JDBC Source
JMS Source
Job lifecycle
Job Lifecycle
join
JSON Web Tokens
jsonPath
jsonPathAdd
jsonPathDelete
jsonPathPut
jsonPathSet
Kafka Architecture
Kafka Connect
Kafka connectors
Kafka consumers
Kafka FAQ
Kafka Introduction
Kafka producers
Kafka public APIs
Kafka Streams
Kafka with Flink
kafka-*-perf-test
kafka-configs
kafka-log-dirs
kafka-topics
Kerberos
Kerberos
Kerberos Properties
Kerberos Properties
Kerberos Service
Kerberos Service
Key Features
Key features of SSB
Keywords
Kudu Sink
Kudu with Flink
lastIndexOf
LDAP authentication
le
length
literal
Log cleaner
Logging In
Logging In
lt
Main Use Cases
Manage Buckets
Manage Bundles
Manage Flows
Manage Groups
Management basics
Managing Nodes
Managing Templates
Maps
matches
matchesRegex
math
Metadata Database
Metadata Database
Metrics
Migrating SQL jobs
minus
mod
Monitoring
Monitoring
MQTT Source
multiply
MySQL
Naming Conventions
NAR Providers
Next steps
Next steps
Next steps
Next steps
Next steps
Next steps
Next steps
Next steps
Next steps
Next steps
Next steps
Next steps
Next steps
nextInt
NiFi
NiFi
NiFi
NiFi Architecture
NiFi CLI
NiFi Components
NiFi diagnostics
NiFi Legacy
NiFi Legacy KDF
NiFi Registry
NiFi Registry
NiFi User Interface
nifi-cert.pem
nifi-key.key
Node Manager
None
not
not
Notes
Notes
Notifiers
Notify
notNull
now
Offload Nodes
Offsets Subcommand
OpenId Connect
Operation Modes
Optional properties
Optional properties
Optional properties
or
Output
Overview
Overview
Overview
Overview
padLeft
padLeft
padRight
padRight
PAM authentication
Parameter Contexts
Parameters
Partitions
PBKDF2
Performing the Work
plus
Port Configuration
Postgres
Predicates
prepend
ProcessContext
Processor API
Processor Locations
ProcessSession
Properties Tab
PropertyDescriptor
PropertyValue
Protection Schemes
Provenance Events
Provenance Events
Proxy Configuration
Proxy Configuration
Querying a schema
Queue Interaction
Quotas
Rack awareness
random
Ranger
Record management
Records
References
Relationship
Release Notes
Remote Querying
Remote Topics
Remove
Removing a Template
repeat
replace
replace
replaceAll
replaceEmpty
replaceFirst
replaceNull
replaceRegex
Replicating Data
Reporting Tasks
Reporting Tasks
Required properties
Required properties
Required properties
Required properties
Required properties
Restore
Restricted
Retries
Run the Processor
Running a Flink job
S2S
S3 Sink
SAML
Scheduling Tab
Schema entities
Schema Registry
Scope
Scrypt
Searching
Security examples
Security examples
Security overview
Security Properties
Security Properties
Session Rollback
Set Property Values
Set Ranger policies
Settings
Settings Tab
SFTP Source
Show Local Changes
Single User
Site-to-Site
Special Privileges
SQL Examples
SQL Jobs Tab
SQL Stream Builder
SQL Syntax Guide
srm-control
Standalone
Start New NiFi
Start the data flow
Start the data flow
Start the data flow
Start the data flow
Start the data flow
Start the data flow
startsWith
startsWith
State Management
State Management
State Manager
StateManager
Status
Streaming Analytics
Streams Messaging
String Manipulation
substring
substring
substringAfter
substringAfter
substringAfterLast
substringAfterLast
substringBefore
substringBefore
substringBeforeLast
substringBeforeLast
Summary Page
Supporting API
Swap Management
Syslog TCP Source
Syslog UDP Source
System Properties
System Properties
System Properties
System Requirements
System Requirements
Tables Tab
Technologies
Templates
Terminology
Terminology
Terminology
Testing
thread
TLS Cipher Suites
TLS encryption
TLS Toolkit
toBytes
toDate
toDate
toDecimal
toLower
toLowerCase
toNumber
Tool usage
Topics
toRadix
toString
toString
toUpper
toUpperCase
trim
trim
Troubleshooting
Troubleshooting
Type Coercion
UI Extensions
unescapeCsv
unescapeHtml3
unescapeHtml4
unescapeJson
unescapeJson
unescapeXml
Unit Tests
Updating a notifier
Upgrading NiFi
Upload Bundle
URL Aliasing
urlDecode
urlEncode
Usage
Usage
Usage
Usage
Usage
Usage
Usage
Usage
Use cases
Use Schema Registry
User Authentication
User Authentication
User Authorization
User Window
UserGroupProvider
Using Apache NiFi
Using Flink CLI
UUID
UUID3
uuid5
UUID5
Validate Output
ValidationContext
Validator
Variables
Verifying the setup
Version States
View a Flow
Web Properties
Web Properties
What to do next
Where to Start?
Why Cluster?
ZooKeeper Migrator
ZooKeeper Migrator
Filter topics
Managing Nodes
System Requirements
Port Configuration
NiFi
Embedded ZooKeeper
TLS Cipher Suites
User Authentication
Single User
Kerberos
OpenId Connect
SAML
Apache Knox
JSON Web Tokens
FileAuthorizer
Access Policies
NiFi Legacy KDF
Bcrypt
Scrypt
PBKDF2
None
Argon2
NiFi Legacy
Required properties
Optional properties
AWS KMS provider
Required properties
Optional properties
Optional properties
Required properties
Required properties
Required properties
Example
Why Cluster?
Terminology
Managing Nodes
Disconnect Nodes
Offload Nodes
Delete Nodes
Decommission Nodes
Flow Election
Basic Cluster Setup
Troubleshooting
State Management
ZooKeeper Migrator
Proxy Configuration
Kerberos Service
Notes
Analytics Framework
System Properties
Core Properties
State Management
H2 Settings
FlowFile Repository
Swap Management
Content Repository
Web Properties
Security Properties
Kerberos Properties
Custom Properties
Upgrading NiFi
Start New NiFi
Processor Locations
NAR Providers
HDFS NAR Provider
NiFi diagnostics
Managing Nodes
Disconnect Nodes
Offload Nodes
Delete Nodes
Decommission Nodes
Parent topic:
Feedback
I like something
I have an idea
Something's not working
Back
Submit
OK
This site uses cookies and related technologies, as described in our
privacy policy
, for purposes that may include site operation, analytics, enhanced user experience, or advertising. You may choose to consent to our use of these technologies, or
manage your own preferences.
Accept all
7.3.1
7.2
7.2.18
7.2.17
7.2.16
7.2.15
7.2.14
7.2.12
7.2.11
7.2.10
7.2.9
7.2.8
7.2.7
7.2.6
7.2.2
7.2.1
7.2.0
7.1.0
7.0.2
