Using Apache NiFiPDF version
Secret Key Generation and Storage using Keytool
The KeyStoreKeyProvider supports reading from a java.security.KeyStore using a configured password to load AES Secret Key entries. The KeyStoreKeyProvider can be configured with any of the encrypted repository implementations.
The provider supports the following KeyStore Types:
  • BCFKS
  • PKCS12
The keystore filename extension must be either .p12 indicating PKCS12 or .bcfks indicating BCFKS.
The keytool command can be used to generate an AES-256 Secret Key stored in a PKCS12 file for repository encryption:
keytool -genseckey -alias primary-key -keyalg AES -keysize 256 -keystore repository.p12 -storetype PKCS12
The keytool command requires additional arguments specifying the BouncyCastle Security Provider to store Secret Keys using BCFKS. The arguments must include a reference to the BouncyCastle Security Provider library, which is available in the lib/bootstrap directory under the NiFi installation.
The following command can be used to generate an AES-256 Secret Key stored using BCFKS:
keytool -genseckey -alias primary-key -keyalg AES -keysize 256 -keystore repository.bcfks -storetype BCFKS -providerclass org.bouncycastle.jce.provider.BouncyCastleProvider -providerpath lib/bootstrap/bcprov-jdk15on-*.jar
Enter a keystore password when prompted. The same value must be used for both the keystore password and key password. The keystore password will be used in the provider configuration properties.
