Cluster Common Properties
When setting up a NiFi cluster, these properties should be configured the same way on all nodes.
Property
Description
nifi.cluster.protocol.heartbeat.interval
The interval at which nodes should emit heartbeats to the Cluster Coordinator. The default value is 5 sec.
nifi.cluster.protocol.heartbeat.missable.max
Maximum number of heartbeats a Cluster Coordinator can miss for a node in the cluster before the Cluster Coordinator updates the node status to Disconnected. The default value is 8.
nifi.cluster.protocol.is.secure
This indicates whether cluster communications are secure. The default value is false.
