AzureGraphUserGroupProvider
The AzureGraphUserGroupProvider fetches users and groups from Azure Active Directory (AAD) using the Microsoft Graph API.
A subset of groups are fetched based on filter conditions (Group Filter Prefix, Group Filter Suffix, Group Filter Substring, and Group Filter List Inclusion) evaluated against the displayName property of the Azure AD group. Member users are then loaded from these groups. At least one filter condition should be specified.
This provider requires an Azure app registration with:
  • Microsoft Graph Group.Read.All and User.Read.All API permissions with admin consent
  • A client secret or application password
  • ID token claims for upn and/or email
See https://docs.microsoft.com/en-us/graph/auth-v2-service and https://docs.microsoft.com/en-us/azure/active-directory/develop/scenario-daemon-app-registration for more information on how to create a valid app registration.
The AzureGraphUserGroupProvider has the following properties:
Property Name Description
Refresh Delay
Duration of delay between each user and group refresh. Default is 5 mins.
Authority Endpoint
The endpoint of the Azure AD login. This can be found in the Azure portal under Azure Active Directory → App registrations → [application name] → Endpoints. For example, the global authority endpoint is https://login.microsoftonline.com.
Directory ID
Tenant ID or Directory ID of the Azure AD tenant. This can be found in the Azure portal under Azure Active Directory → App registrations → [application name] → Directory (tenant) ID.
Application ID
Client ID or Application ID of the Azure app registration. This can be found in the Azure portal under Azure Active Directory → App registrations → [application name] → Overview → Application (client) ID.
Client Secret
A client secret from the Azure app registration. Secrets can be created in the Azure portal under Azure Active Directory → App registrations → [application name] → Certificates & secrets → Client secrets → [+] New client secret.
Group Filter Prefix
Prefix filter for Azure AD groups. Matches against the group displayName to retrieve only groups with names starting with the provided prefix.
Group Filter Suffix
Suffix filter for Azure AD groups. Matches against the group displayName to retrieve only groups with names ending with the provided suffix.
Substring filter for Azure AD groups. Matches against the group displayName to retrieve only groups with names containing the provided substring.
Comma-separated list of Azure AD groups. If no string-based matching filter (i.e., prefix, suffix, and substring) is specified, set this property to avoid fetching all groups and users in the Azure AD tenant.
Page Size
Page size to use with the Microsoft Graph API. Set to 0 to disable paging API calls. Default: 50, Max: 999.
Claim for Username
The property of the user directory object mapped to the NiFi user name field. Default is 'upn'. 'email' is another option when nifi.security.user.oidc.fallback.claims.identifying.user is set to 'upn'.
Like LdapUserGroupProvider and ShellUserGroupProvider, the AzureGraphUserGroupProvider configuration is commented out in the authorizers.xml file. Refer to the comment for a starter configuration.
