Legacy Authorized Users (NiFi Instance Upgrade)
If you are upgrading from a 0.x NiFi instance, you can convert your previously configured users and roles to the multi-tenant authorization model. In the authorizers.xml file, specify the location of your existing authorized-users.xml file in the Legacy Authorized Users File property.
Here is an example entry:
<authorizers>
    <userGroupProvider>
        <identifier>file-user-group-provider</identifier>
        <class>org.apache.nifi.authorization.FileUserGroupProvider</class>
        <property name="Users File">./conf/users.xml</property>
        <property name="Legacy Authorized Users File">/Users/johnsmith/config_files/authorized-users.xml</property>
        <property name="Initial User Identity 1"></property>
    </userGroupProvider>
    <accessPolicyProvider>
        <identifier>file-access-policy-provider</identifier>
        <class>org.apache.nifi.authorization.FileAccessPolicyProvider</class>
        <property name="User Group Provider">file-user-group-provider</property>
        <property name="Authorizations File">./conf/authorizations.xml</property>
        <property name="Initial Admin Identity"></property>
        <property name="Node Identity 1"></property>
    </accessPolicyProvider>
    <authorizer>
        <identifier>managed-authorizer</identifier>
        <class>org.apache.nifi.authorization.StandardManagedAuthorizer</class>
        <property name="Access Policy Provider">file-access-policy-provider</property>
    </authorizer>
</authorizers>
After you have edited and saved the authorizers.xml file, restart NiFi. Users and roles from the authorized-users.xml file are converted and added as identities and policies in the users.xml and authorizations.xml files. Once the application starts, users who previously had a legacy Administrator role can access the UI and begin managing users, groups, and policies.
The following tables summarize the global and component policies assigned to each legacy role if the NiFi instance has an existing flow.xml.gz:
Admin DFM Monitor Provenance NiFi Proxy
view the UI
access the controller - view
access the controller - modify
access parameter contexts - view
access parameter contexts - modify
query provenance
access restricted components
access all policies - view
access all policies - modify
access users/user groups - view
access users/user groups - modify
retrieve site-to-site details
view system diagnostics
proxy user requests
access counters
view the component
modify the component
view the data
modify the data
view provenance
For details on the individual policies in the table, see Access Policies.
