Using Spark SQL
This section provides information about using Spark SQL.
  • Interactive access using the Spark shell (see "Accessing Spark SQL through the Spark Shell" in this guide).
  • From an application, operating through one of the following two APIs and the HiveServer2:
    • JDBC, using your own Java code or the Beeline JDBC client
    • ODBC, through the Simba ODBC driver
The following subsections describe how to access Spark SQL through the Spark shell, and through JDBC and ODBC.
