Using Spark Streaming
This section provides information on using Spark streaming.
Before running a Spark Streaming application, Spark and Kafka must be deployed on the cluster.
Unless you are running a job that is part of the Spark examples
package installed by Cloudera Data Platform (CDP), you must add or
retrieve the CDP spark-streaming-kafka
.jar file and
associated .jar files before running your Spark job.
Spark Streaming is an extension of core Spark that enables scalable, high-throughput, fault-tolerant processing of data streams. Spark Streaming receives input data streams called Discretized Streams (DStreams), which are essentially a continuous series of RDDs. DStreams can be created either from sources such as Kafka, Flume, and Kinesis, or by applying operations on other DStreams.
You can process data using complex algorithms expressed with high-level
functions like map
, reduce
join
, and window
, and send results
to file systems, databases, and live dashboards.
For detailed information on Spark Streaming, see Spark Streaming Programming Guide in the Apache Spark documentation.
Spark Streaming receives live input data streams and divides the data into batches, which are then processed by the Spark engine to generate the final stream of results in batches:
![](../images/streaming-flow.png)
Apache Spark has built-in support for the Apache Kafka 08 API. If you want to access a Kafka 0.10 cluster using new Kafka 0.10 APIs (such as wire encryption support) from Spark streaming jobs, the spark-kafka-0-10-connector package supports a Kafka 0.10 connector for Spark streaming. See the package readme file for additional documentation.
The remainder of this subsection describes general steps for developers using Spark
Streaming with Kafka on a Kerberos-enabled cluster; it includes a sample
pom.xml
file for Spark Streaming applications with Kafka. For
additional examples, see the Apache GitHub example repositories for Scala, Java, and
Python.
