Working with DataPDF version
SQL for first table
For datasets created from a SQL query, you can modify the query at any time to adjust fields, update the WHERE clause, change the ORDER BY sequence, and more.
  1. Click the icon.
  2. Make the desired changes to the SQL statement.
  3. Click SAVE to apply the changes.
    To test your updates, click RUN before saving the updated SQL query.
