Working with DataPDF version
Working with data profiling
Learn how you can profile your datasets. Dataset profiling provides a high-level overview of your data, offering insights into structure, content, and quality. This feature allows you to quickly assess the suitability of your data for analysis, and helps you identify the appropriate visualizations and any necessary data transformations.
With dataset profiling, you can access detailed statistics for dimension or measure in your dataset, including data type distributions, missing values, and unique values, as well as more in-depth information such as column distribution charts and statistics. These insights help you better understand the quality and characteristics of your data, ensuring it is suitable for the intended analysis or visualization.
  1. Click DATA on the main navigation bar.
    The Data view appears, open on the Datasets tab.
  2. Find the dataset that you want to profile, either by scrolling through the list or using the search function.
  3. Click the dataset you want to examine.
    The dataset side navigation pane opens for the selected dataset, displaying the Dataset Detail page.
  4. Click Dataset Profiling in the left-side navigation panel.
    The Dataset Profiling view appears, with the option to select fields from the dimensions and measures of the dataset.
  5. Select the fields that you want to examine and click Explore.
    Cards with various statistics and visual representations of the selected fields are displayed.
    The following information is shown for dimension values:
    Most frequent
    The string that appears the most often in the dataset, helping to identify the most common value.
    Least frequent
    The string that appears the least often in the dataset, helping to identify rare or unusual values.
    Number of Empty string
    The count of cells that contain an empty string, for example cells that are not null but contain no characters.
    Empty cells
    The number of cells that are completely empty, including both null values and empty strings.
    Record count
    The total number of records in the dataset.
    Duplicated rows
    The number of rows that are exactly identical, helping to identify redundant data. A high number of duplicates often signifies low variability in the dataset.
    Distinct count
    The number of unique values in the dataset, showing how varied the data is.
    Longest word
    The string with the highest number of characters in the dataset, providing insight into the potential size of values.
    Shortest word
    The string with the fewest number of characters, indicating the shortest data entry.
    MIN
    The minimum value in the dataset based on alphabetical order, useful for sorting or range analysis.
    MAX
    The maximum value in the dataset based on alphabetical order, helping to define the upper range of the data.
    The count histogram for dimensions shows how many times each category appears, that is the number of occurrences (counts) of each category (dimension). This visualization is useful for understanding the quality, distribution, and structure of your dataset.
    The following information is shown for measure values:
    MIN
    The smallest numeric value in the dataset, showing the lower bound of your data.
    MAX
    The largest numeric value in the dataset, showing the upper bound of your data.
    Avg (Average)
    The sum of all numeric values divided by the total number of records, giving an overall sense of the central value.
    Standard Dev
    Standard deviation that shows how spread out the numbers are in the dataset. A higher value indicates more variability in the data and a lower value indicates that the data points are closer to the average.
    Number of Zeroes
    The count of records where the value is exactly zero, indicating gaps or null-equivalents in the data.
    Empty cells
    The number of cells that are completely empty, including both null values and missing values.
    Record count
    Duplicated rows
    The number of rows where all values are identical, helping to identify redundant data. A high number of duplicates often signifies low variability in the dataset.
    Distinct count
    Most frequent
    The numeric value that appears the most often in the dataset, helping to identify the most common value.
    Least frequent
    The numeric value that appears the least often in the dataset, helping to identify rare or unusual values.
    The frequency histogram for measures shows the distribution of numeric values (measures) within specific ranges (buckets), giving insight into their spread and common ranges.
